Meth Install *PICS*
Old Dec 17, 2009 | 08:30 AM
  #31
supergengo's Avatar
Originally Posted by Hiboost
I used a similar setup on my 96 Eclipse GSX that shared the washer reservoir and it worked out fine. The intake got stained a bit blue inside over time but was clean otherwise. This was back about 8 years ago and the kits now are much more well thought out, they really do allow a solid 3-4 more psi safely on pump gas along with better timing.
I still want to run Meth/Water, just using the stock washer fluid reservoir for a more stealthy install.
Old Dec 21, 2009 | 08:15 AM
  #32
scheides's Avatar
EvoM Moderator
^for sure, except meth as a washer fluid kinda sucks (IMHO).
There's got to be room for that 1-gallon tank in the space the pump and stock battery live, with a mini-battery kit. Anyone tried this yet?
Old Dec 22, 2009 | 01:45 AM
  #33
Jabjab's Avatar
thought about this, but when you add more meth it would be a pain in the ***
Old Jan 31, 2010 | 08:02 PM
  #34
NateDaJew's Avatar
Great install. Why did you pick AEM over the Aquamist etc?
Old Feb 8, 2010 | 08:53 PM
  #35
Jabjab's Avatar
sorry I forgot to check this post and didn't see your question
My friend had installed his aem on his X and he knows the ends and outs of the kit, also talked to a bunch of installers and vendors and they all loved it for the money its hard to beat.
plus if you want more fail safes you can add the ones from the Aqua to this kit
but damn that Lil gauge looks nice
Old Feb 26, 2010 | 09:42 PM
  #36
Jblade's Avatar
this may be a silly question but is that green light you had installed to let you know your spraying just a light or is it a button as well? meaning is your meth pump always on as long as the car is on or do you hit the button to turn it on?
Old Feb 27, 2010 | 08:20 AM
  #37
abazaba410's Avatar
Very Clean! Amazing Job... If I knew more about Meth Id do it. But Im too much of a puss.
Old Feb 27, 2010 | 08:33 AM
  #38
NYC-X's Avatar
That's an honest man right there. Real clean install you are really swaying me towards meth right now!
Old Feb 27, 2010 | 10:44 PM
  #39
Jabjab's Avatar
oh its just a light, it turns on when I start the car to let me know its working. and soon as I hit about 14 pounds of boost it kicks on and starts slowly spraying all the way to 30 pounds of boost at full blast.
Light stays on the whole time its spraying. so basically if you just drive normal and keep the boost under 14psi. you wont even use the meth.
Its so worth it, especially for the people who have 91 oct.
Old Feb 27, 2010 | 10:45 PM
  #40
Jabjab's Avatar
Thanks Everyone!
Old Mar 2, 2010 | 07:07 AM
  #41
tonyboy's Avatar
clean install and thanks for this thread jabjab! i made use of the pump and tank's location the same as mine..
Old Mar 4, 2010 | 10:16 PM
  #42
Enjoitk's Avatar
im convinced that i want this now!
Old Mar 5, 2010 | 10:56 PM
  #43
Jabjab's Avatar
you wont regret it
shrty10135
Oct 21, 2010 04:49 PM
