Evo X E85 Conversion How To & Discussion
Old Mar 3, 2011 | 07:00 PM
  #76
Ian0611's Avatar
Subscribed. It looks like you follow most of the same steps for the 8/9 but does anyone know of any differences or another thread that talks about this for the 8/9? I tried to searching but didn't find anything nearly this detailed.
Old Mar 6, 2011 | 09:09 AM
  #77
Drew-EVOX's Avatar
Thanks! A lot of things I just learned
Old Apr 6, 2011 | 10:06 AM
  #78
detroitms3's Avatar
Thank you for an excellent write up on DIY E85!
Old Apr 10, 2011 | 09:26 AM
  #79
KevinD's Avatar
we do quite a few e85 conversions around here with the map switching. it helps that there are quite a few e85 stations in the DFW metroplex though
Old Apr 17, 2011 | 09:30 AM
  #80
hockey88's Avatar
Thanks for the info. Hopefully E85 will become more readily available in MD soon
Old Apr 17, 2011 | 03:26 PM
  #81
tjac357's Avatar
any how to for the flex fuel sensor?
Old Aug 24, 2011 | 09:27 AM
  #82
bonsuz01's Avatar
nice write up...
Old Oct 9, 2012 | 11:30 AM
  #83
noypi13's Avatar
Very informative, TY
Old Oct 11, 2012 | 08:33 AM
  #84
1010's Avatar
Originally Posted by goofygrin
  • Zeitronix ECA (Details). This will tell you how much ethanol is in the gas you're running. This isn't cheap, around $200 + the flex fuel sensor ($100 to $350). However it sure beats wondering if you're running rich because of the ethanol content or a boost leak. Installing the flex fuel sensor will require some though as it has a 5/16 fitting and a 3/8 fuel fitting on it (you'll need another adapter, or use one of the lines that you cut to install the fuel filter.
The website says the flex sensor's maximum lph is 200. That's too little. Wouldn't the bottleneck kill your e85 delivery? Pity, I love my Zr-2
Old Oct 11, 2012 | 09:41 AM
  #85
murlo26's Avatar
You could always run a two line system. T if off before sensor, run small line to sensor that recombines with main line before rail somewhere.
Old Oct 11, 2012 | 11:53 AM
  #86
1010's Avatar
I'm no expert but there's no terminator it's only 1 T-off. I think you'd need to the continuous pressure. Without it you'd be below the 300 lph and your performance would suck.
Please someone alot smarter than me prove or disprove
Old Aug 6, 2013 | 08:09 AM
  #87
JinxsEvoXMR's Avatar
at what point do you need to run a bigger fuel rail with e85? i'm planning on a red build. also, will a single 255 and 1300 injectors be enough for the red? thanks
CO_VR4
Oct 25, 2016 05:30 PM
EvoX-11
Jul 5, 2013 06:17 AM
240Z TwinTurbo
May 4, 2013 12:49 PM
murlo26
14
Sep 27, 2012 10:38 PM
uvambo
May 2, 2011 09:39 AM
