Gears won't go in
Old Feb 24, 2010 | 08:30 PM
RREvoxGSR's Avatar
yeah it actually goes into gear, when i actually try to start it in gear the car just dies out.
Old Feb 25, 2010 | 06:41 PM
Bighec's Avatar
Well sounds like your clutch isn't engaging for one reason or another. If you are 100% positive that your clutch master is ok I think you are going to have to drop your tranny and have a look around and see what came undone.
Your car is physically going into gear. The reason why it is shutting off is because the clutch isn't being engaged.
Old Feb 26, 2010 | 09:10 PM
prodigy1210's Avatar
What clutch did you install?
Old Feb 27, 2010 | 12:08 AM
RREvoxGSR's Avatar
i have an act hdg6 clutch with a stock flywheel.
Old Feb 28, 2010 | 07:00 AM
boostin20's Avatar
Just like BigHec mentioned, if you're absolutley sure your clutch master cyl, line, hose, slave cyl, and fork operation are ok, then it's time to pull the trans and look at tob and clutch to find your issue.
Old Feb 28, 2010 | 07:05 AM
Wickedwhite8's Avatar
I had a similar problem. Mine goes into every gear but third when clutch is pressed. When I shift without the clutch is goes in like butter. I adjusted the pedal and it helped alot but not 100%. try adjusting you pedal
Old Mar 1, 2010 | 09:10 PM
RREvoxGSR's Avatar
evo x pedals can't be adjusted
Old Mar 2, 2010 | 05:32 PM
RREvoxGSR's Avatar
how would i know if the master cylinder needs to be replaced? it's not leaking fluid or anything. anyone have any response with the act hdg6 clutch?
Old Mar 3, 2010 | 12:59 PM
RREvoxGSR's Avatar
ttt
Old Mar 4, 2010 | 12:50 PM
VRSF Tiago's Avatar
If your master or slave cylinder need to be replaced your clutch pedal will drop to the floor and won't pop back up. That's assuming pressure is lost in the assembly.
That's assuming complete failure of either assembly. Not to sure what the symptoms would be on the assembly if they were on their way out.
From everything I've read I'd guess it's an issue with the clutch or tob.
Old Mar 9, 2010 | 08:15 PM
RREvoxGSR's Avatar
Well.. I just took out the clutch today, first pressure plate looked fine. Then I unbolted the pressure plate and guess what.. clutch disc was stuck on the flywheel, I actually had to pry it with a screwdriver. I've had a talk with ACT already and I'm shipping it tomorrow for them to inspect it.
Old Mar 10, 2010 | 06:25 AM
Mj23foreva's Avatar
I think I'm gonna go with Exedy after what youve just gone through, at least you figured out whats wrong and it was costly to fix.
Old Mar 10, 2010 | 10:52 AM
RREvoxGSR's Avatar
Well, so far they have gave me good customer service and is going to inspect it for me. I'll have to ship it out and see what they say. Hopefully they will warranty it for me though.
Old Mar 10, 2010 | 11:08 AM
Webman's Avatar
I think you're saying it backwards. The clutch isn't DISengaging. Thus why it won't go into gear when engine is running, but works fine when it's off.
Old Mar 10, 2010 | 07:23 PM
Bighec's Avatar
YOU KNOW WHAT I MEAN!!!
