Mobil 1 5w-30 EP vs Mobil 1 0w-40 (Oil Analysis)
So if you think M1 oil isn't good enough for your EVO... here is proof. Everyone can run about 6000 miles on both oil daily driving.
For about $27 bucks @ Advance Auto Parts 5qts with filter. 0w-40 is a real bang for the buck.
The results from the 0w-40, were from a modded car. I say that you are more than fine to run 5000 miles to be on the safe side. I will bump up my interval to 5000 miles, since summer is a bit more harsh on the oil due to increased ambient temp.
Because the TBN is still very high for both oil as well as they only sheared down a grade. So a 30w oil is now a 20w and a 40w oil is now a 30w oil, so you can run the 40w oil for a longer interval until it starts to shear down to a 20w. Either way, these engine have high tolerance and a turbo which shear the oil down very fast. If you want more protection, which I doubt there is a need to spend more money on oil, you can go with Redline 0w-40, but will cost you double the price of M1, should hold off the shear better. I wanted to try German Castrol, but they do not sell it around me. So I am sticking to 0w-40 for now. I will send another oil analysis in 20k miles (~ 1 year driving for me).
I run fully modded with almost all bolt on's. I did not add my mods to this analysis, the first one had all my mods.
EvoM Community Team
Mr.. i clearly stated that i was not going to come in here in the begining because there was no mention of AMSOIL , however some pages down AMSOIL was mentionned in the mix,,, i and i will make it clear to you that there was no AMSOIL peddling here,, i pay dues unlike you that are a voluntary moderator and i have all the right to answer anything related to AMSOIL.
Like I said, if you want to create your own "amsoil vs. XYZ brand" thread, please do so. But, this is not the thread to discuss amsoil.
