stock clutch life
stock clutch life
Hey guys
My stock clutch kicked the bucket last weekend... it had a little over 18k miles on it... i was as kind to the car i could possibly be, i mean i took it to the most hilly part of manhattan every day for school
Just wonder how long it was until your stock clutch started to slip and burn out
I just started this thread last week..
https://www.evolutionm.net/forums/ev...ed-so-far.html
I only have 14k miles so far and its fine. One guy has 75k miles!
Location: driving the 10 second beast in ohio or running lightmods.net
3,200 miles , 16 autocrosses with tons of clutch smell the last 5 events, my clutch still worked but was aweful. i haven't saw such a blue center clutch disc and the backside was melted into one puck . check out the thread i am about to put up with a bit of info on the setup i am running
I had 55k miles when my stocker started to slip at higher boost/rpms (shortly after a cam install/retune). Shifts were still clean and I took care of it, always matching revs before letting it out, etc. I launched it a handful of times in 3 years, the only track it ran on were roadcourses.
I replaced it with a Fidanza 3.2 and am very happy.
1) you'll smell it
2) when you go into gear you engine will start rev-ing when you depress the gas and then the revs will drop and then you'll start moving*
3) worst case scenario you can't get moving from a dead stop which would suck
those are just a few that i've heard there are probably more
as for cost, i just got mine replaced for $1600 and it was done at the dealer, so now i have a brand new OEM clutch and flywheel... some after clutches cost that amount just for the assembly
manny ways:
1) you'll smell it
1) you'll smell it
wow that is really expensive as what i heard .. and ill keep those in mind ..
thanks!
manny ways:
1) you'll smell it
1) you'll smell it
manny ways:
1) you'll smell it
1) you'll smell it
im getting a stage 1 exeddy clutch and lightened flywheel combo delivered to my door for 850$ labour for install is 200$
My stock clutch went out around 18k miles, it sucked pretty bad, it was slipping in every gear, i replaced with a ACT HD street disc and fly and it feeels like what an evo should feel like now. cost for the kit + fly with labor $1800 good luck with your clutch buddy.
