Anyone tried a blow through setup?
Old Jun 24, 2010 | 10:18 AM
EVODreams's Avatar
I have seen it a lot on subarus, just curious if anyone has done it on a X? I know the VIII and IX's Maf won't do it, but the X looks like it could easily be done..
Old Jun 24, 2010 | 11:19 AM
ETS Michael's Avatar
I remember a customer trying it back in the day, but if I recall correctly he had a ton of CEL to deal with and always in limp mode. Not sure if he ever got it resolved though. It does work good on the Subaru's though.
Michael
Old Jun 24, 2010 | 08:05 PM
El_Kameleon_G's Avatar
Here's some reading for ya: https://www.evolutionm.net/forums/ev...tmosphere.html
Old Jun 25, 2010 | 07:53 AM
Guru's Avatar
I am on blow through now but I believe I Have a cam timing problem so going to remove cam cover hopefully this weekend to fix. Let's hope that is the issue and not the blow through because car runs terrible.
Old Jun 26, 2010 | 06:40 AM
cpunlamd's Avatar
I remember everyone in the DSM community running the GM after MAF. What ever happened to that??
Old Jun 26, 2010 | 06:47 AM
EVODreams's Avatar
^ this is what I was thinking, but with the evo X Maf a blow through setup would be easy.
Old Jun 28, 2010 | 10:38 AM
Speed Density ECMLINK.
Old Jun 28, 2010 | 11:46 AM
EVODreams's Avatar
I see that it supports SD and BT, but just on DSM and 1-3 Evos. Nothing there in relation to Evo 8,9,10's
Old Jun 28, 2010 | 11:52 AM
8/9 use stock ecu to convert to speed density. The X is uncharted unless your using an AEM, Motec, GEMS etc.
Old Jun 29, 2010 | 02:02 PM
Guru's Avatar
I am hoping they have speed density with stock ECU as an option soon for the X. Tephra just released first round of mods. That will make my life a WHOLE lot easier.
Old Jul 5, 2010 | 06:42 AM
Guru's Avatar
My Blow through setup is up and running (had injector issue). Works fantastic and no problems as of yet. Does need a little tuning but working on a CEL issue at the moment.
kevin salazar
Aug 11, 2016 06:05 AM
ohYouEvo
Apr 6, 2016 02:23 PM
MVPCO
May 2, 2014 06:47 AM
AWDTerror
Oct 23, 2012 05:27 AM
JKav
14
Apr 1, 2009 12:30 AM
