4b11 internals strength
Old Dec 27, 2012, 07:33 AM
  #31
Sunwalker12's Avatar
The rods, cast, are inherently the weak point on the 4B11T. Hench the reasoning for the 375wtq cap...the pistons, however, are forged. I would say that the limits to this motor seem to be around the 400whp/375wtq range w/stock internals.
Old Dec 27, 2012, 08:19 AM
  #32
ETS Michael's Avatar
Over 200 dyno runs and constant street abuse at 680whp on stock block. - I wouldn't recommend much above 500-550whp on a T3 setup (less torque). The weak point we found after tons of abuse was the rod bolts stretched and let go. We did hit right around 40psi a couple times on the dyno with no head gasket problems, but if you plan on running high boost I would recommend rod bolts. So far the 4B11 has been one of the strongest motors we have had the joy of working with.
If you plan on running a bolt on turbocharger this will all change. You will put a ton more load down low with the increase in torque and the rod bolts may stretch a bit earlier due to the constant torque abuse. T3 at these power levels is the only way to go.
Michael
Old Dec 27, 2012, 05:16 PM
  #33
luvboost's Avatar
^ good info. Glad to have some solid info with credible companies and not just hearsay.
Old Dec 27, 2012, 05:22 PM
  #34
KurtP's Avatar
so assuming a good tune,you feel like changing the HG, h3ad studs, and rod bolts significantly increases the reliability?
whay do you suggest for a simple drop in piston/rod package?
Originally Posted by ETS Michael
Over 200 dyno runs and constant street abuse at 680whp on stock block. - I would recommend much above 500-550whp on a T3 setup (less torque). The weak point we found after tons of abuse was the rod bolts stretched and let go. We did hit right around 40psi a couple times on the dyno with no head gasket problems, but if you plan on running high boost I would recommend rod bolts. So far the 4B11 has been one of the strongest motors we have had the joy of working with.
Michael
Old Dec 28, 2012, 08:26 AM
  #35
Our car has very simple build.
Cosworth drop in pistons
Cosworth rods and bearings
Cosworth headgasket
ARP Rod Bolts
GSC S2 Cams
Ferrea Dual Valve Springs and Retainers
Stock block (No sleeves)
Stock head (no porting or oversize valves, you can benefit on increasing the exhaust valve size though)
This was a built 2.0L
Thanks!
Michael
Old Dec 28, 2012, 08:43 AM
  #36
murlo26's Avatar
Originally Posted by escodotcarter
4g63>4b11
iron>aluminum
closed deck>open deck
thank you for your completely worthless post
Old Dec 28, 2012, 08:51 AM
  #37
lol
Old Dec 28, 2012, 09:12 AM
  #38
E-SPEC INDUSTRIES's Avatar
Michael
Old Dec 28, 2012, 09:15 AM
  #39
escodotcarter's Avatar
Says the completely unbiased evo X owner. Everyones entitled to their own opinion.
Old Dec 28, 2012, 09:18 AM
  #40
murlo26's Avatar
I've owned both, have you?
And I don't come into a random threads and derail them off topic talking about something totally unrelated.
The 4b11 has no issues if people build them right and in stock form many have lasted plenty long.
If the car wasn't weighed down with improved safety factors there wouldn't be a comparison, Mitsubishi designed a great car.
That being said the 4g63 is an awesome platform that I personally love and I will buy another one in the future.
Old Dec 28, 2012, 09:21 AM
  #41
your win sir, not here to make enemies
Old Dec 28, 2012, 10:45 AM
  #42
KurtP's Avatar
Cosworth headgasket
ARP Rod Bolts
GSC S2 Cams
Thanks!
Michael
The cossi pistons require modification to the oil squirters don't they?
No gains to head porting or changing intake valve?
Old Dec 28, 2012, 10:56 AM
  #43
Kracka's Avatar
4g63>4b11
iron>aluminum
Don't be a hater. Own and drive both then come to your own factual opinion.
For me:
IX: 40k miles
X: 50k miles and climbing
Old Dec 29, 2012, 12:10 PM
  #44
humpevo311's Avatar
For me:
IX: 40k miles
I agree, I like my 10 more than my 04 evo 8, I still love the 8/9 but have no reason to switch sides. I'd rather be on the boat discovering new things than just settling for old hat. My X in current form feels every bit as strong as my old 8 did with similar mods. The downpipe install on the x however, was a complete pain in the ***. LOL I'm currently debating doing a rod and piston build before I need to. Just so that's out of the way. We'll see.
Old Jan 25, 2016, 09:09 PM
  #45
NateDaJew's Avatar
Bringing it back from the dead. I'm currently running over 500whp but I'm ready to go over 600. I ask my shop for an ideal turbo but I'm being told I need to sleeve my block and basically rebuild the bottom end. ETS do you think it necessary to spend another 10k just to break 600whp? I spent over 5k building the last motor after my chain stretched. Check out my sig for my upgrades. I appreciate any opinions.
TEXAS TRAVISTY
Outlander Sport
58
Feb 25, 2021 05:48 PM
Blacksheepdj
Lancer Engine Tech
35
Dec 2, 2017 03:48 PM
Bvettevo
Mitsubishi TC-SST Discussion
Jan 10, 2017 07:32 PM
Subawho_02
May 16, 2016 05:49 PM
evox_4x4
For Sale - Part Outs
Feb 28, 2016 09:48 PM
Quick Reply: 4b11 internals strength
