Transfer Case & Rear Diff Fluid bleeding concern
Old Nov 28, 2010 | 01:35 PM
derekste's Avatar
You don't need to bleed any of these
Old Nov 28, 2010 | 01:37 PM
derekste's Avatar
Anyone who says you need to bleed has clearly never done this before, nor have they read the factory service manual
Old Nov 28, 2010 | 07:13 PM
BGM3's Avatar
Originally Posted by HR2L
Def need to bleed the system if you plan to change fluid. Hydraulic systems + introduced air = No good.
If you look in the manual, all the fluids are changed with a simple drain and refill procedure. There will always be air above the fill plug in these chambers. The manual is unclear in stating that the "hydraulic" systems are separated into the pressurized chambers (the pump, and lines) and the lubricating chambers (transfer case, rear diff)
tiesto14
Jun 4, 2016 03:51 AM
silentsniper605
15
Oct 14, 2015 05:33 AM
ChipperEvo
Sep 24, 2015 12:36 PM
al3lwan
Jan 31, 2014 10:29 PM
mshilto89
Feb 27, 2013 06:27 PM
