MAP o2 DUMP downpipe
Old Jan 12, 2011 | 11:17 AM
  #106
ChrisCarey's Avatar
Haha wow looks like MN last month!
Old Jan 12, 2011 | 11:54 AM
  #107
maperformance's Avatar
Holy Cow Rob!
Old Jun 29, 2011 | 01:36 PM
  #108
tonyboy's Avatar
hi, sorry to revive this old thread..looking into buying an o2/dp again.. i'm leaning towards your product..was just wondering what was the resolution or the workaround for the weak a$$ valve cover of 2010?
Old Jun 29, 2011 | 01:42 PM
  #109
ChrisCarey's Avatar
I haven't heard of any issues from the DP, just tubular manifolds I believe?
Old Jun 29, 2011 | 01:44 PM
  #110
Yes, I believe it was just tubular manifolds but you can run DEI's reflect-a-gold tape on it to keep it from melting.
Old Jun 29, 2011 | 03:26 PM
  #111
tonyboy's Avatar
oh i misunderstood your discussions with Kracka then my bad
Old Jun 29, 2011 | 04:49 PM
  #112
No problemo!
Old Jun 29, 2011 | 05:24 PM
  #113
Kracka's Avatar
Correct x2
MAP o2 elim dp here on my 2010 and zero issues; I did get it ceramic coated though. I've had it since last November (~10k miles so far).
Old Jun 29, 2011 | 06:36 PM
  #114
tkromer's Avatar
Pardon my ignorance, but what's the difference in this type of downpipe and a "traditional" one?
Old Jun 29, 2011 | 08:50 PM
  #115
Standard downpipe doesn't delete the o2 housing, ours does.
Old Jun 30, 2011 | 03:52 AM
  #116
tkromer's Avatar
Well I kind of got that -- I guess what I'm asking is what's the benefit to no O2 housing as opposed to just an extender or something to get the sensor a bit more out of the direct flow?
Old Jun 30, 2011 | 05:36 AM
  #117
ugakirk's Avatar
The downpipe alone is very short and just replaceing that gives you no gains at all. It's better to replace the downpipe/O2 with a better aftermarket one, for example, AMS's widemouth, ETS's downpipe/o2, Map's downpipe/02, which I will be buying soon .
Old Jun 30, 2011 | 06:32 AM
  #118
tkromer's Avatar
I think that explains it!
In my Sky -- the only turbo car I've had any real work on, the downpipe and cat/02 were all one pipe. About 3' long. I assumed this to be the same.
Old Jun 30, 2011 | 06:55 AM
  #119
Kracka's Avatar
The "o2 housing" is also called the turbo outlet elbow. O2 elim downpipes do not delete the factory catalytic converter, you will need a HFC or testpipe for that. My guess is MAP could weld their o2 elim dp and testpipe together for you making one big o2/cat elim dp.
Old Jun 30, 2011 | 07:24 AM
  #120
tkromer's Avatar
So in this car, two pipes prior to the catback.
