Engine Winding Noise
Old Apr 10, 2012 | 08:03 AM
jyamona's Avatar
I just started hearing an odd noise a few days ago. It doesn't make it until the car is very hot...like after doing WOT pulls or driving at higher speeds for awhile.
With the windows closed reving the car slightly, it almost sounds like a winding noise, as if you were cranking an electric motor by hand or something.
As the rpms rise from 1k - 3.5k it becomes more of a hum w/ it being the loudest around 3.3k. Any higher it doesn't get any louder and seems to go away almost.
Car makes the noise when
- reving in neutral w/ clutch out
- reving w/ clutch pushed in
- while driving in gear
Any ideas?
Old Apr 10, 2012 | 08:53 AM
Widoww's Avatar
Leak down test..and boost leak tests. Any cyl misfires?
Get it looked at sooner then later!
Old Apr 10, 2012 | 10:51 AM
jyamona's Avatar
No misfires, and no boost leaks tested to 30psi
Old Apr 10, 2012 | 01:17 PM
dacowgod's Avatar
I'd take it to the dealer and make them aware of it (if its under warranty) ... What you're explaining is how I would explain the sound of a failing oil pump :-/ ... Obviously I could be wayyy off base but its certainly possible..
Old Apr 11, 2012 | 06:02 AM
jyamona's Avatar
warranty? where? hah...nah, I have full bolt-ons and it's certainly too much effort to put the stock o2/dp and stuff back on for a trip to the dealer =/
1.8t
Dec 30, 2011 08:15 AM
select21
Oct 9, 2010 07:34 AM
evane
Aug 29, 2008 11:32 AM
Eyre
10
Jan 11, 2007 02:37 PM
finbarqs
Jun 24, 2006 03:18 AM
