You're Tired of These Threads but... Build Help
I know there are a ton of threads like this and I read them but I would still like some help. I'm no car guru so what I need is an exact part list to meet my goals.
My main priority is a reliable daily driver. Second would be quick spool and around 400-425whp without building the engine. Budget around 10k - 15k including labor but if I can get away with spending less that's great.
Currently only power mods are boltons which include:
- ETS test pipe back
- UICP
- HKS filter
- Perrin inlet
- Accessport
- AMS front mount (not installed)
- Grimspeed 3port (not installed)
Need to buy:
- Clutch - ?
- Flywheel - ?
- CMC - (AMS)
- Turbo - ?
- Injectors - ?
- Downpipe - (AMS)
- Intake - ?
The need to buy are parts off the top of my head that I know I will need. I'm sure I'm missing items so please let me know.
Thanks
- UICP
- HKS filter
- Perrin inlet
- Accessport
Need to buy:
- Clutch - ?
- Flywheel - ?
- CMC - (AMS)
- Turbo - ?
- Injectors - ?
- Downpipe - (AMS)
- Intake - ?
Thanks
- UICP
- HKS filter
- Accessport
Need to buy:
- Clutch - ?
- Flywheel - ?
- CMC - (AMS)
- Turbo - ?
- Injectors - ?
- Downpipe - (AMS)
- Intake - ?
Thanks
- UICP
- HKS filter
- Accessport
Need to buy:
- Clutch - ?
- Flywheel - ?
- CMC - (AMS)
- Turbo - ?
- Injectors - ?
- Downpipe - (AMS)
- Intake - ?
Thanks
turbo. fp green or map ef2 or similar stock frame turbo. quick spool and good usable power.
downpipe.
intercooler.
fuel injectors.
fuel pump.
tune.
that setup should be good for ~400 whp on a dynojet on 93 octane. total should be around $4000 if you do the labor yourself.
no need for clutch or flywheel unless u burn the clutch up.
- UICP
- HKS filter
- Accessport
Need to buy:
- Clutch - ?
- Flywheel - ?
- CMC - (AMS)
- Turbo - ?
- Injectors - ?
- Downpipe - (AMS)
- Intake - ?
Thanks
- UICP
- HKS filter
- Accessport
Need to buy:
- Clutch - ?
- Flywheel - ?
- CMC - (AMS)
- Turbo - ?
- Injectors - ?
- Downpipe - (AMS)
- Intake - ?
Thanks
Although honestly I'd say do all your full bolt on's first and get tuned. I think that power is plenty for a daily and fastest spool you'll get. Stock turbo should be good for 360 to 370whp if set up and tuned right.
no, you shouldn't. the safeness of the tune will be the primary dictating factor but if everything is right, the bottom end is good to around 400+ ft/lbs of torque. some will say even up to 450 but just know anything beyond that you are really stressing the stock bottom end and could throw a rod on a high gear pull.
GrnEVO
Oct 16, 2016 08:22 AM
tsitalon1
Jul 7, 2010 01:11 PM
maxum17ft
Lancer Aftermarket Forced Induction Tech
107
May 27, 2006 06:56 PM
