Flywheel
Old Aug 1, 2012 | 06:17 AM
NVmeSTI's Avatar
Flywheel
I just orderd a stage 1 HD exedy clutch because my clutch went out. Now I find out I need a new flywheel. What should I get
Old Aug 1, 2012 | 06:53 AM
Kracka's Avatar
You can reuse your stock flywheel, just have it resurfaced. If you insist on a new aftermarket one MAP has a nice aluminum one with replaceable steel friction rings.
Old Aug 1, 2012 | 02:33 PM
NVmeSTI's Avatar
mine has hot spots in it id rather buy a new one im at 345whp so dont want that breaking. i was wondering why a lightweight one is bad? and id rather not have aluminum because of heat.
Old Aug 2, 2012 | 06:14 AM
Kracka's Avatar
You're not going to break a stock flywheel, especially at such a mild power level
Lightweight isn't necessarily bad, just be aware of what you're getting yourself into before purchasing. Low-speed drivability and idle with A/C on will not be as smooth as stock, and you will have to be quicker with the clutch than you're currently used to. I had a lightweight flywheel on my IX but don't plan on doing one on my X since it's my daily-driver that sees all types of traffic and road conditions, and my goal is to keep it as smooth as stock so anyone can jump in and drive it.
No aluminum because of heat? Aluminum dissipates heat more quickly than steel. If you prefer a steel one though, there are plenty on the market such as Competition and ACT.
Old Aug 3, 2012 | 05:06 PM
NVmeSTI's Avatar
I know that the aluminum get rid of heat quicker but it can't stand as mch heat. My dad has aluminum heads and they got to hot and messed up
Old Aug 5, 2012 | 01:48 PM
Kracka's Avatar
Your car has an aluminum head and block
hutch959
Dec 5, 2016 05:10 PM
mr.almeida
23
Jan 17, 2016 01:47 PM
duderr_666
58
Aug 18, 2015 10:44 AM
jg8352
17
Apr 25, 2014 06:59 AM
srivera2010
Apr 9, 2013 10:56 AM
