Help!Grumbling noise from downpipe?
Old Oct 19, 2012 | 08:13 AM
Fall of pride's Avatar
Unhappy Help!Grumbling noise from downpipe?
I have a cnt high flow cat downpipe, along with that i have an ets intake. I have been driving with the downpipe for about 3 weeks now and just recently installed the intake a week or so ago and now my car is making a strange low grumble that seems to be coming from the downpipe. To be more specific, it doesn't make the noise at idle or acceleration, only when i close the throttle and the rpms are between 2500-2000, then when i begin braking it also stops. Any theories are much appreciated!
Old Oct 19, 2012 | 10:32 AM
EAGLE 5's Avatar
My theory is...
CAVEAT: I'm assuming you're not tuned
Your ECU has gotten used to the Intake being there and started adding fuel to compensate for more air which causes your car to backfire just a little. Now that you have a high flow cat the backfiring is more pronounced.
If you're tuned I guess that still applies but I don't think it would be as pronounced. Point is when you replace restrictive exhaust components like cats, and mufflers you hear more sounds including backfiring etc.
EDIT: To be on the safe side if you can make sure you haven't developed an exhaust leak on the part you replaced that could also add some unwanted noise.
Old Oct 19, 2012 | 01:57 PM
nastorino's Avatar
Are you using any engine management? Ecuflash, AP or Protuned?
Old Oct 20, 2012 | 07:14 AM
Originally Posted by EAGLE 5
My theory is...
Thanks for the reply and you are correct in the fact I'm not tuned yet, I was going to wait a month until I got intercooler pipeing and then get it pro tuned, this shouldn't cause any issues should it? Thanks again!
Old Oct 20, 2012 | 11:06 AM
nastorino's Avatar
Are you at least flashing it with a cobb ap or ecuflash software? Please don't tell me you slapped on an intake and a turbo back without a tune....if so don't drive the car until she's tuned, terrible idea.
Old Oct 21, 2012 | 04:08 PM
Ya, i have an AP but i just feel like a protune will pull out some more power. I actually replaced the gasket and it seems much better now, thanks for the help! I am also just being a bit overly paranoid because this is my frist really nice car and i dont want to break it lol. Thanks again!
Old Oct 25, 2012 | 11:13 AM
EAGLE 5's Avatar
In that case I'm definitely sure that's backfire from fueling. I read that Cobb's OTS tunes work with more fuel and less boost to keep detonation at bay plus add the fact you got a less restrictive exhaust and voila` you got a nice soundtrack.
Where in TX btw?
Old Oct 26, 2012 | 06:59 AM
Where in TX btw?
Mckinney! (so just a bit north of dallas) ya, im much less woried now cus I've have a few others tell me its fine, I'm just cautious!
ramsfan6239
Aug 19, 2014 06:18 PM
russ72
Jun 30, 2014 09:01 AM
Dave221982
Jun 8, 2013 04:43 PM
evox4b11turbo
Apr 22, 2013 05:06 PM
initialdrew
20
Nov 6, 2012 04:58 PM
