Tcase, Trans and axles oh my!
I'm going to try this thread here because the General section is not giving any love.
Please tell me this isn't my transfer case, axles, transmission or anything else major...
It only makes this sound at low speeds, from a stop with the wheel turned and a little gas....just enough for the Traction Control to kick in. It's winter here and slippery so it doesnt take a lot of gas. I've turned off the TC and the noise still kicks in.
It's almost like something is vibrating under the car. I don't feel any vibrations in the car at all. I don't feel anything...just hear the sound and mechanically everything feels fine.
I would love to think thats all it is but Im doubting it. If anything something might be rubbing against a heatshield or something.
So frustrating.
Well I guess this isnt a very common sound/issue to happen to the evo's
So frustrating.
First, our power-steering pumps are dead silent; anything that you believe to be related to a PS pump is just a boost leak. [/inside-joke]
If this were my car, I'd take it to a U-wash-it place and blast that entire wheel-well. It's surprising to many how often that solves these things.
I'm also curious if this only happens when the car is very cold. Mine makes a few driveline noises when cold which I just ignore. It can be as simple as immobile grease in the outer CV-joint cup. Yeah, it's causing a bit more wear than usual (since most noises come from metal-on-metal contact), but it's nothing to freak out about.
First, our power-steering pumps are dead silent; anything that you believe to be related to a PS pump is just a boost leak. [/inside-joke] If this were my car, I'd take it to a U-wash-it place and blast that entire wheel-well. It's surprising to many how often that solves these things. I'm also curious if this only happens when the car is very cold. Mine makes a few driveline noises when cold which I just ignore. It can be as simple as immobile grease in the outer CV-joint cup. Yeah, it's causing a bit more wear than usual (since most noises come from metal-on-metal contact), but it's nothing to freak out about.
It's freeIng *** cold here for at least another month so I won't know until spring time
Iowa I hope you are right that it's probably a noise caused by cold and nothing to worry about.
I'm pretty **** though so I'm getting all of my fluids checked at the end of the month. If the fluids are okay which I'm sure they are I'll ask them about this and see if they have had any complaints about it.
I think you are right though Iowa, it's probably nothing as the car drives fine, even when the noise occurs.
EvoJustin
16
Nov 24, 2013 10:57 PM
