Wastegate Preload?
Wastegate Preload?
So I've been having issues with my gtx3576r for quiet some time now and thanks to a couple of people here in the forum I finally figured out that the wastegate that came with The turbo was crap. I went out and got a Turbosmart wastegate with a 18psi spring. I put the wastegate on and notice that I'm only boosting 20psi. I'm on e85 so I should be boosting at least 26-27psi. My question is do I have enough preload? Shorting the arm a little more? Or do I get stiffer spring? I have an ebc by the way. I do have an air compressor and when I blow air into the wastegate it'll "crack" open at 18psi. I have it set to the standard preload which is 3 full turn.
Are you actually tuning boost via the ECU? An 18psi wastegate spring and the car is making 20psi of boost sounds like you're running 0 wastegate duty cycle.
Are you tuning boost at all with the ECU?
Frew
14
Aug 25, 2013 04:20 PM
propellerhead
May 18, 2004 11:13 AM
