5858 no boost?
Old Aug 10, 2017, 09:28 AM
jsdude's Avatar
5858 no boost?
I had a 5858 turbo kit with built 2.0 tuned by english racing running at 26psi. I was on the freeway wot on 4th gear about 6k rpm and shifting to 5th gear, all of the sudden there was NO boost on 5th. I did not notice any weird sound whatsoever, boost gauge still shows negative pressure on idle. Engine was idling just fine. Will it be the wastegate got stuck open or the turbo failure? Any other thoughts will be helpful.
Old Aug 10, 2017, 10:01 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Check for charge piping blown off
ETS Michael (Aug 10, 2017)
Old Aug 10, 2017, 10:20 AM
ETS Michael's Avatar
jsdude's Avatar
Everything is in place nothing has fail off
Old Aug 10, 2017, 10:55 AM
Need to do a boost leak test to know for sure.
- Robert
Old Aug 10, 2017, 11:05 AM
If the turbo failed, there would noises and smoke. If the wastegates were stuck open, you would hear exhaust constantly coming out of the dump tubes. Make sure something didn't go through the intercooler
Old Aug 10, 2017, 11:13 AM
jsdude's Avatar
- Robert
I think i did not clarify what I meant by no boost. On the boost gauge, its always negative even im wot, and it struggle to climb on rpm felt like there wasn't a turbo.
Old Aug 10, 2017, 11:38 AM
Yeah, sounds like your classic massive boost leak.
Old Aug 10, 2017, 01:03 PM
Yep, boost leak test should be 1st step. Might look like couplers are all on there but it could have ripped a hole in the coupler, blown out the intake manifold gasket, ETC. Boost leak test is step one.
- Robert
Old Aug 17, 2017, 01:28 PM
jsdude's Avatar
Update - external wastegate got stuck open. Problem fixed
Old Aug 18, 2017, 12:32 PM
thanman99's Avatar
Has anyone had to oil up the rod to wastegate connection? howd you fix it?
01sporty
Apr 13, 2012 06:01 PM
4ag18psi
Apr 10, 2012 05:57 PM
sLowEvX
Apr 6, 2012 07:02 PM
sLowEvX
Apr 4, 2012 08:06 PM
JDM EVO 6
Feb 22, 2012 08:08 PM
Quick Reply: 5858 no boost?
