Evo x GSR Oil filter
On my stock setup I used the extended performance M1 filters and never had any issues. I used that and the extended performance oil as well, but just changed at normal 3K miles intervals. Comparison between normal M1 and the Ext Perf at similar milage showed the ext perf oil was holding up noticeably better.
I should probably also add Buschur Racing recommend the Wix filter for my built engine and Brad Penn, the green oil (which is Penn Grade now), 10w40 in the winter and 20w50 in the summer. But I certainly wouldn't run those viscosities on the stock engine.
i read an article a few days ago that said Royal Purple is the best all around oil filter. 100% synthetic material, high flow rate, super efficient, strong build... mobile 1 and the Wix were both high on the list as well. The factory filter is actually pretty good too.
Honestly any of them should be fine, Mobile 1, Wix, Royal Purple, stock Mitsubishi... as long as you do your oil changes at the correct interval.
chamelieon
Jan 12, 2013 06:26 PM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
Joshm3357
Oct 13, 2011 08:10 AM
mrcox
Apr 14, 2007 09:35 AM
