Evo x Xtreme twin plate carbon clutch
Is anyone running a Xtreme twin plate carbon clutch? How do you like it? Pros/cons? Would you recommend for a daily driven 300awkw Evo X?
How much torque does the car make? Sounds like a way overkill clutch for the application.
I agree it seems to be a huge overkill , I'm looking at making more power in the future but nothing over 300kw.
at $1900 it hard to justify.
I was leaning more towards a Xtreme heavy duty organic clutch and resurface the existing flywheel.
any recommendations will be appreciated
400Nm is 300ftlbs American. So, you literally don't even need an upgrade clutch. If your stock clutch is worn out, an ACT HDSS (HD pressure plate with organic disc) is all you need. And that clutch will be fine for what you can safely make on the stock motor, which is about 400wtq (where the stock motor is safe). That would be about 540Nm.
Hell, the stock clutch will hold 400wtq.
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
54
Jun 1, 2010 01:04 PM
Emperor666
Mar 24, 2007 08:33 AM
Speed Element
Jan 9, 2007 03:09 PM
ez76
19
Sep 7, 2004 04:20 AM
