Transmission Error Message
I bought my 2014 EVO GSR used with 35,000 miles in December 2017. A month after I started getting transmission errors and my clutch would slip, when I would press the gas I would not move at all. I would have to rev the engine in order for my clutch to catch. So I thought the problem was the clutch because the fluids were good. So I upgraded the clutch to a ACT Stage 2 Clutch and the flywheel was burnt to hell so I replaced it with a ACT light weight flywheel. After replacing everything and doing a transmission/transfer case and master cyclinder flush I am still having the same problem. I also had a shop make sure all the air was out of the system. I attached the error messages if anyone has ran into this problem can you let me know the best option to take.
Thank You!
ASC System Service Required
4WD System Service Required
Thank You!
That's not a trans error. That's stability control and 4wd errors. That can be caused by a few different things. What shop did the work?
Ultimate CC
Feb 2, 2006 10:44 AM
