BR EVO X, weight information.
I started weighing and comparing some things this morning. I don't have a huge list compiled yet but will work on it as I go. I will keep updating this. We are using our digital corner scales to measure each part.
STOCK PARTS Muffler only, 29 pounds Catback pipe, 14 pounds **Catback complete weighs in at 43 pounds Stock cat, 15 pounds Stock air box, 9.7 pounds Stock upper i/c pipe, 3 pounds Stock spare tire and hold down bolt, 41 pounds Stock wood panels and carpet in the trunk, 8 pounds Jack and tools, 6 pounds Stock FMIC, 12 pounds Stock battery, 35 pounds Stock battery tray, tie down and bolts, 2.5 pounds Stock lower i/c pipe, 3 pounds Vibration damper (located behind stock FMIC) 3 pounds BUSCHUR RACING AFTERMARKET PARTS BR True Dual 304 grade SS, 3" catback, 20 pounds (23 pounds lighter than stock) BR offroad pipe, 5 pounds BR air filter kit, 1.5 pounds BR lightweight battery kit with aluminum tray, 14 pounds BR upper i/c pipe kit, 7.2 pounds BR lower i/c pipe kit, 6.7 pounds |
looks good, dang i didn't know the spare tire and bolts weighed that much.
i like it when i see an after market part that adds power and loses weight. |
wow...nearly 150 lbs off...nice job DB!
171.7 Lbs!!!! Geez, awesome work guys! Stocker parts are heavy huh?!
Originally Posted by CtSilver03Evo
(Post 5348002)
Awesome list, thats some pretty sweet and easy weight saving mods...
Originally Posted by EVIL_EVO_VIII
(Post 5348015)
Well realistically hes not taking all that weight off since parts do have to be put back on. Shaves a few pounds here and there
Can't count the FMIC and IC Pipe as there was no weight given for there replacements so it works out to around 114lbs saved.
Any ballpark figures, for the weight of the BR FMIC?
The savings is much smaller than you guys are coming up with. The aftermarket parts have to be subtracted from the stock parts.
Originally Posted by davidbuschur
(Post 5348567)
Very informative post, thank you{thumbup} I still get about 109lbs even adding your parts back in, minus whatever your intercooler weighs.
This is going to be a tough car to get very light without cutting it up. It really needs some weight taken out of it.
Our FMIC core is going to be heavy. I am using a large core in the car and should have it in there next week. |
Can we get a sticky with this information saved please?
It's a sticky on our site PDX, www.buschurracing.com Just go to the forums and then to the EVO X section.
