Oil Change
i need to get an oil change.
the dealer charges 75 dollars to do it and only 20 if you bring your own oil. if i wanted to change it my self is there a procedure to reset the milage thing on the screen in the gauge cluster?? |
check the manual to confirm, but i think you just have to go the maintenance screen while the engine is off and hold down the menu button to reset.
thats all you do.
alright thanks:thumbup:
I did that, and the display went from "5 months / 4000 miles" to "10 months / 9000 miles"... WTF? I followed what the owners manual said to do, and this was the result!
Keith |
they adjusted mine at the dealership. had it set to every 4000 to change it. button combination thing sucks tho... where's the "menu" ?
Almost there!
Originally Posted by Fourdoor
(Post 6127505)
Keith with engine off .. press and hold (~2sec) 3 times then press 3 times quick succession to get to the selection menu .. think it cycles JPN10/11/20/21/30/40 NAS10/11/20/21 EUR AUS GPP OPTION OFF |
****! $75!
Change the oil yourself and go to the dealer and have them reset it if you can't figure it out. We've had people do that at my job. It takes 3 second, we never charge them. |
Since this is some of the routine maintenance in the book, how do you get the stamp if you do it yourself??
