Those with the MR's
Just wondering, what sort of RPM's are you running at highway speeds? The GSR is running like 4 grand... just curious and I couldn't find it anywhere.
just below 3k
Originally Posted by Cyp
(Post 6538716)
just below 3k
I think at 80 the GSR is at 3800-3900rpm. The MR is under 3k? Wow, MR's must get A LOT better gas mileage on the highway. I'm guessing this is the reason there aren't any MR MPG ratings out there (that I know of anyways)?
-X |
25mph per 1000rpms .. 75mph is 3000rpms
RPMs are anywhere from 3200-3600 @ 80mph, depending on grade and conditions, if I recall. I've been able to "hypermile" up to 26 MPG combination city/highway on 93 octane, but it takes too much effort, and honestly, I never really cared that much about my gas costs. I average closer to 20-21 MPG on my commute if I'm driving normally. Errands, more like 17 MPG.
<deleted, double post>
1 Attachment(s)
Pic attached with my MR in 6th, at indicated 76 MPH. It's about 3200 RPM.
The GSR badly needs another gear or longer ratio's.
Originally Posted by Q15H
(Post 6540173)
120kmh =75mph and it sits right at 3000rpms :p |
Originally Posted by sporkmonger
(Post 6540081)
That is absolutely not true. The RPMs at one given gear will not change at the same speed, there is no conditions that will change that.. If you are driving with the same gear and increase the spped then the RPMS will increase. If you are in the same gear and increase the rpms then the speed will increase as well. What you are saying is that there is some fluctuation on rpms at 80mph which is totally false. Carlos |
(Post 6540173)
Carlos |
(Post 6540173)
-X |
Originally Posted by fromWRXtoEVO
(Post 6544559)
If you are driving with the same gear and increase the spped then the RPMS will increase. If you are in the same gear and increase the rpms then the speed will increase as well. What you are saying is that there is some fluctuation on rpms at 80mph which is totally false. Carlos Eddie Rosado |
GSR definitly should have been a 6 speed.. maybe the 2010s will be 6 speed
| All times are GMT -7. The time now is 06:41 PM. |
