-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   car won't hold boost (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/447877-car-wont-hold-boost.html)
robh Sep 21, 2009 03:34 AM
like the title says
anyways i had my car on the dyno this sat i can get the car to spike just about what ever i want for boost but no matter where i set target boost it will tapper to 20 to 21 psi
we have boost leak checked it
compression check
leakdown test
tightining the wga
have tried
mbc
ebc
ecu boost
all three do the same thing
my mods are
fp red
cos mx1 cams and spring
perrin front mount
ttr hard pipes
forge bov
forge wga
fuel pump
ur exhaust (with test pipe)
aquamist hfs1
dw 800 cc inj
so no matter what we do the boost will spike hold tell about 4500 to 5000 rpm then drop to 21 psi
so if anyone has any ideas please post them up
my results so far are 430 whp and 377 wtq
thx
tonyboy Sep 21, 2009 05:02 AM
i'm assuming the boost leak checked out fine right? anyway, ooohh what i'm thinking is a bad red...hopefully not...
robh Sep 22, 2009 03:31 AM
do you guys think if i go to an external 44mm wg this will fix my issue?
Arutha Sep 22, 2009 04:39 AM
just had a similar problem with my car. the actuator on the FP red can only sustain about 22psi running a pretty heavy duty cycle. you'll have to look at upgrading it to a heavier duty one
EvoX2NR Sep 22, 2009 04:53 AM
he had a forge unit on there at one point with the same issue
FedEvo8 Sep 22, 2009 05:32 AM
Try swapping out the BOV to the stock one and see if it holds.
murlo26 Sep 22, 2009 08:33 AM
I have seen more than one fp red hold 25 at redline, something is goofy.
I agree, put the stock DV back in, that has been an issue with others. My DV works at 30+ psi, you should be fine.
tweakdsm Sep 22, 2009 08:39 AM
boost leak test is your friend.
check your BOV, MBC, and WGA.
robh Sep 22, 2009 09:30 AM
i boost leak check the system up to 27 psi with no leaks
i have changed the bov to the stock and then back again
i best i can get it to hold is 22 to 23 psi with the avcr duty cycles maxed out and the wastegate preload very tight
i guess im going to order a new down pipe with the 44mm external wg and hope for the best
Tommyfacekicker Feb 3, 2017 12:55 PM
Old but were u ever able to fix the problem?
lui_ming_92 Feb 13, 2017 02:19 PM
Vaccum leak can also the cause of this
RazorLab Feb 13, 2017 03:52 PM
Did you really bump a eight year old thread?
btw, the stock turbo cannot sustain more than 20-21 psi out the top. This is normal for it to taper boost.
Tommyfacekicker Mar 10, 2017 01:10 PM
Yes I did because I'm having boost target issues. I would like to know if anyone can recommend a fix to this? I did all of the same stuff the OP did but I'm not able to see high psi at all. Only seeing 22 psi all the way to redline. This is an old thread so someone should have some helpful tips rite?
4G63_EVO Mar 10, 2017 07:45 PM
what turbo setup and what WGA
Tommyfacekicker Mar 10, 2017 09:12 PM
I'm running a Arashi 25g turbo and the wg that it came with. The turbo is only 4 months old. Never really got into boost bec I was untuned. It has no shaft play, does not burn oil, no smoke. My buddy is running the same exact turbo with no issues. I'm on e85 w/ all the supporting mods and using a mac ebc. Compression test was good. Boost leak test was bad at the throttle body so I got a brand new fb 70mm tb. Haven't got a chance to do a new boost leak test since the new tb was installed last week. The car feels great but I'm only getting 22 psi. I was aiming for 30 psi and then gonna turn it up to 33 psi.
