Cost for upgrading turbo and tune
Hi all
I am new to upgrading cars but would like to get my X to around 450hp :Dkeeping it street legal:lol:. My question is how much should I be looking to spend including installation and maintainance etc. for an upgraded turbo and an ECU tune from AMS etc. Would I run into any kind of problems? I have 15K miles currently on car and an aftermarket ACT street racing clutch installed by a dealer. Also looking to get AMS downpipe and tp but no catback. thanks{thumbup} |
Atleast 5k$
3-4k
just for turbo and retune...assuming you go for an FP red, walbro fuel pump, and upgraded injectors...3-4k is accurate. but to really reach 450whp you need bolt-ons as well.
some simplified math:
1400 turbo 400 injectors 200 fuel pump/housing 500 downpipe 200 test pipe 700 install 500 tune ------- 3900 300 lower ic pipe 300 upper ic pipe 700 intercooler 700 cams 300 intake 500 install 200 retune ------- 3000 and now i just realized how much money ive spent |
Originally Posted by midwestX
(Post 7661875)
Hi all
I am new to upgrading cars but would like to get my X to around 450hp :Dkeeping it street legal:lol:. My question is how much should I be looking to spend including installation and maintainance etc. for an upgraded turbo and an ECU tune from AMS etc. Would I run into any kind of problems? I have 15K miles currently on car and an aftermarket ACT street racing clutch installed by a dealer. Also looking to get AMS downpipe and tp but no catback. thanks{thumbup} Just saying top-end horsepower isn't always the best.{thumbup}
Originally Posted by tokeone
(Post 7662628)
1400 turbo 400 injectors 200 fuel pump/housing 500 downpipe 200 test pipe 700 install 500 tune ------- 3900 300 lower ic pipe 300 upper ic pipe 700 intercooler 700 cams 300 intake 500 install 200 retune ------- 3000 and now i just realized how much money ive spent Never add up the cost! LOL |
(Post 7662628)
1400 turbo 400 injectors 200 fuel pump/housing 500 downpipe 200 test pipe 700 install 500 tune ------- 3900 300 lower ic pipe 300 upper ic pipe 700 intercooler 700 cams 300 intake 500 install 200 retune ------- 3000 and now i just realized how much money ive spent lol 3-4 grand try 8-9 grand |
Do you already have a catback or are you planning on running an upgraded turbo with the stock catback/muffler? If the later, you are going to be quieter for sure but bottling up most of the exhaust side gains from the turbo to the test pipe making them minimally effective. You always want to improve your flow working your way from the outside towards the engine.
Originally Posted by youlost
(Post 7663035)
Didnt include catback, gauges, or clutch...
lol 3-4 grand try 8-9 grand although for me the gauge and cat back weren't that bad (700 i believe) and im at 51k with the stock clutch... so for like 7500 you can have what i have. |
Originally Posted by Hiboost
(Post 7663910)
Anyway I will start adding money and i know I got a long way to go but I am glad I live 10 minutes from AMS:cool:. Maybe by Christmas I will have a tune and bolt-ons and enjoy that first:lol: before becoming a hardcore Does anyone know if I can get AMS ECU flash just with dp/tp & AEM intake? many thanks{thumbup} |
A catback will reduce backpressure which is always good for a turbocharged car. The only possible time I can see it reducing power is off boost for under a second from 1500-2000 rpm, and even then some adjusting with Mivec settings can make that a non-issue.
On the same token you are reducing backpressure on the exhaust system bu replacing the O2 Downpipe and Testpipe but you won't see the full gains by doing those without the catback because the muffler section especially is still a bigger restriction. |
If you want to archive 450hp, you have a couple options. You can run a stock replacement turbo, but you will be running close to 30psi to archive the goal or you could go with a 35R kit and archive your goal at 23-24 psi.
https://i4.photobucket.com/albums/y1...vs_redcopy.jpg ETS HTA3586 vs FPRED - 26psi The turbo spools a little later, but you will see a huge difference in top end performance. Instead of going with an HTA3586 we could put on a Precision 6057 or 5857 and make 500whp and spool just as fast as the red. My vote is on the turbo kit. Lower PSI and More Power. Thanks! Michael |
If you want to run pump gas, sure get a big turbo.
As everyone knows the FPred isn't a pump gas turbo, it just isn't. But if you throw E-85 in there or Race gas, it really shows its true colors. Pump gas I agree with ETS, probably better to go with a small 35r twinscroll for your power levels or a DOM2/FPgreen for spool if you need that. However, I think he was just wondering cost. The full turbo kit will cost more always, so that is also an issue. Your looking at 4 grand minimum plus all the supporting mods. Bolt on's are always cheaper and get most people to their goals with better spool. |
Originally Posted by murlo26
(Post 7668352)
