ACT Prolite Flywheel
Does anyone have an ACT Prolite Flywheel in there Evo X?? I know in the 93.5-98 Twin Turbo Supra's if you install the light flywheel the trannys chatter and rattle at idle. I'm just wondering if the Evo Rattles as well with a light flywheel.
I have it...it doesn't rattle.
I have the streetlite version and mine seems to work fine as well.
I have a street lite, but not installed yet. LOL
Why did you not go prolite?
Originally Posted by murlo26
(Post 8565450)
Originally Posted by twinturbogreg
(Post 8565542)
(Post 8564879)
Yes I'm sure... It's not the flywheel rattling. It's the gearbox. The V-160 Getrag trans has a very heavy gear set and does not do well with the light flywheels.
Originally Posted by pstl_pete
(Post 8565687)
Are you sure that was the trans rattling at idle that you heard? Typically twin or triple disk clutches rattle at idle. A flywheel should not be able to rattle since its one single piece.
Most people would want the Streetlite. The Prolite makes it harder to leave from a stop but the motor revs a little freer -- obviously that's great for road courses because you only stop in the pits but need to rev match constantly.
