-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   AKUMA EVO X: AKUMA's new 2.2L and more (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/577206-akuma-evo-x-akumas-new-2-2l-more.html)
AkumaMotorsport Oct 1, 2011 02:36 PM
I wanted to start this thread to update what we are doing with the shop Evo X. I had a thread up a while ago, but there are so many changes, I though it would make sense to start over.
Basically I had the opportunity to develop our new stroker motor with our machinist and throw it in the EVO X. Shep really hooked us up with a trans overhaul and a new final drive as well. Headgames is doing the head, and I will get it tuned.
Here are the specs of the new build:
AKUMA 2.2L Shortblock
-JE Asymmetrical pistons Coated
with upgraded pins**Retains Oil Squirters**
-Manley Rods- Turbo Tuff Pro I Beam
-Manley Billet Crank-94mm 33lbs
-ACL bearings
-Cosworth thrust Bearings
-Akuma Spec ARP Headstuds---See pics below, they are HUGE!
-Mainline honed/Cyl Torque Plate Honed/Blueprinted/Balanced
-Head work by HEADGAMES:
-Valve job
-Ferrera valves(inconnel Ex)
-Combustion chamber shaping
-Cosworth DUAL Spring and Ti retainer set
-KELFORD C Cams***
-Cosworth Head Gasket
-Head gasket matched to Akuma Spec Head studs
These are most of the other mods on the car... :)
-FP Black Ball Bearing Turbo
-Fullrace Header-coated
-TBE: Tomei Ti cat Back and test pipe
-Akuma I/C Pipe kit with ETS 4" core
-KW Competition 2 way coilovers-corner balanced and aligned@ Akuma
-Aquamist Meth Injection
-Cusco chassis bracing
-Whiteline Sway-Re
-Recaro Profi seat and Personal Wheel
-Akuma Surge Tank + Bosch 044 + FIC 1100cc +Cosy rail and FPR
-Akuma Firewall
-Carbonetic twin Carbon Clutch
I will have it assembled next week and on the dyno the middle of the following week, but here are some pics to start
http://i576.photobucket.com/albums/s...s/IMG_1004.jpg http://i576.photobucket.com/albums/s...s/IMG_1003.jpg http://i576.photobucket.com/albums/s...s/IMG_1002.jpg
This is the 1/2" Headstud vs to standard ARP stud...
http://i576.photobucket.com/albums/s...s/IMG_1006.jpghttp://i576.photobucket.com/albums/s...s/IMG_1005.jpg
MRevolicious Oct 3, 2011 08:39 AM
cant wait to see the results!
hotstix Oct 3, 2011 08:43 AM
why did you use JE pistons instead of the manley that go with that stroker kit?
AkumaMotorsport Oct 3, 2011 01:54 PM
This is not an off the shelf stroker kit. I chose the JE Asymmetrical pistons because of their design. The forging is very similar to the Cosworth piston design. The obvious difference being the asymmetric skirt. This design has a few benefits on paper, from weight savings to knock resistance. Manley has some very nice products, but the new JE design has the edge in this department.
I have the head coming back on Weds. so I should have it on the road Thursday...tuning the following week or possibly Saturday. Once I have actual data, I can then put up a much more detailed follow up post.
John
hotstix Oct 3, 2011 03:33 PM
Turbo Tuff Crank+Turbo Tuff I beams+Platinum series 2618 Manley Pistons =Off the shelf Manley stroker kit. Only difference here looks appears to be the JE pistons (custom ordered?) that is that same stroker kit I am using in my current build, except I am using the Manley pistons. JE looks like Very nice stuff also, are they 2618?
Looking forward to the results. Good luck with the rest of the build.
http://photos-h.ak.fbcdn.net/hphotos..._2715387_n.jpg
http://photos-b.ak.fbcdn.net/hphotos..._6998459_n.jpg
manio Nov 7, 2011 12:01 PM
Any updates?
AkumaMotorsport Nov 7, 2011 01:37 PM
We had an issue with the motor..
https://www.evolutionm.net/forums/ec...-thoughts.html
an update will be posted in the future when we receive the engine again.
Mike@Akuma
