-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   Surge/stutter at low rpm's? (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/585680-surge-stutter-low-rpms.html)
kt411gcn Nov 24, 2011 07:15 PM
I'm currently running full-bolt ons along with a custom tune and a cobb bpv (currently set to 50/50 recirc). I recently had a boost leak test and they told me I have a slight leak. Right now my main problem is the engine seems to stumble here and there at low rpm's and low boost/cruising with slight load. On rare occasions I experience surge/stutter at low rpm's when I let off.
Im guessing it's the bpv..should I tighten or loosen the spring?
kt411gcn Nov 28, 2011 04:05 PM
Noone?
Vivid Racing Nov 28, 2011 04:21 PM
Have you ruled out all other potential causes of the boost leak?
kt411gcn Nov 28, 2011 06:09 PM
They found that one of my couplers were bad so they replaced that, and they told me that my bpv was leaking slightly.
