-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   Transfer shaft removal - it's stuck! (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/611571-transfer-shaft-removal-its-stuck.html)
kelvinTME May 13, 2012 02:16 AM
In the middle of changing the clutch in my X and am having trouble removing the shaft between gearbox and transfer.
I'm using a slide hammer as per the previous 20 times I've done this on previous evo's but this one just won't budge!
Any suggestions?
I'm guessing the inner clip is sitting slightly out of the groove and stopping it from moving.
:helpme:
scheides May 13, 2012 05:17 PM
Get a bigger slide hammer? There should be nothing special about removing it, make sure there's no tension coming from the other side or anything...just yank yank yank.
<--MOVE OVER May 13, 2012 07:07 PM
I used a puller to get mine out and it worked perfect
GL!
Mr Gears May 14, 2012 05:43 AM
This method works for me every time.
http://www.youtube.com/watch?v=DH5h0uKkKC8
