-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   What's the purpose of changing ATF in rear diff? (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/645508-whats-purpose-changing-atf-rear-diff.html)
dek0026 Feb 5, 2013 05:28 AM
Please close...
Kracka Feb 5, 2013 06:29 AM
The drain/fill ATF portion in the rear diff is separate from the AYC/ADC hydraulic ATF system. The hydraulic portion does not require frequent maintenance.
dek0026 Feb 5, 2013 06:42 AM
Do you have any official or technical material on this?
migs647 Feb 5, 2013 07:03 AM
Since Kracka already answered the main question, I have a question of my own.
It seems in the NW we don't have a problem with the ACD going out like NE does. Supposedly it has to do with temps (we get cold here too just not as cold) and possibly NE using salt on roads (we use gravel). If it is salt / cold related, wouldn't it be wise to change out the ACD fluid a bit more often to prevent internal corrosion / breakdown?
dek0026 Feb 5, 2013 07:06 AM
I would think abuse from the track would be considerably more taxing on the fluid than cold weather and salt used on the roads.
And I'm not totally convinced by Kracka's answer to my question.
Kracka Feb 5, 2013 07:08 AM
http://www.mitsubishiparts.net/catal...079%20copy.jpg
dek0026 Feb 5, 2013 09:23 AM
^thats just info on how to service it.
dek0026 Feb 5, 2013 03:15 PM
I found my answer. This thread can be closed or deleted since it's useless.
migs647 Feb 5, 2013 05:55 PM
Wanna share what you found?
