ACD/AYC pump failure reports
Greetings!
This thread is for reporting ACD/AYC pump failures in Evo Xs. Please do not use this thread for anything else. It is being set up to document the issue. Please copy the format of the following (which is also the first report): year: 2008 first sold: 10/2008 pump started to fail: 26,000 miles (10/2012) pump failed: 28,000 miles (4/2013) - edit: confirmed motor seized 7/2013 cold-start reflashed: never * both Eastern Iowa Mitsu dealers have said that the pump is not covered by the 5-year PT warranty |
year: 2008
first sold: ? pump started to fail: ? pump failed: ~68,000 (4/2013) cold-start re-flashed: ? ( I bought it used.) |
Year: 2010
First Sold: Dec 2010 Pump started to fail: April 15, 2013 / 42,000 miles Pump Failed: April 28, 2013 /42 43,000 miles Cold start re-flash: April 25, 2013 *Vehicle purchased used and was not covered under powertrain warranty |
year: 2008
first sold: 7/2008 pump started to fail: 38,000 miles (11/2012 ) <-- guestimate pump failed: 40,000 miles (02/2013) cold-start reflashed: yes right when it was made available Powertrain warranty up next month and i'm still fighting with the dealer to get them to cover it under warranty. Fuel pump is covered under powertrain, water pump covered under powertrain but not AYC pump wtf :/ Evox forums also has a compilation list http://www.evoxforums.com/forums/showthread.php?t=58221 |
year: 2008
first sold: 2/2008 pump started to fail: ~53,000 miles (3/2012) pump failed: ~54,000 miles (4/2012) cold-start reflashed: ? (2nd Owner) |
year: 2010
first sold: 10/2010 pump started to fail: 27,500KM pump failed: Waiting on replacement currently cold-start reflashed: ? |
Here ya go.
year: 2008 first sold: 11/2008 pump started to fail: 42,000 miles (3/2013) pump failed: 42,700 miles (4/2013) cold-start reflashed: never * Mitsu dealers have said that the pump is not covered by the 5-year PT warranty. No way will I pay over $2 grand for the dealer to fix it. Looking into other options. . . |
year: 2010
first sold: 6/2010 pump started to fail: 56,723 (6/2013) <- 4 days before bumper-to-bumper warranty ends pump failed: ? cold-start reflashed: ? note: dealer I went to submitted a claim right after the initial check-up, waited for the replacement part about 2.5 weeks... and finally warranty replacement done |
year: 2008
first sold: 7/2008 pump started to fail: 38,000 (5/29/2013) pump failed: 38,200 cold-start reflashed: no |
year: 2008
first sold: 5/2009 pump started to fail: 85Mm (2013/Feb) pump failed: Same cold-start reflashed: Yes |
year: 2010
first sold: 1/2010 pump started to fail: 26,000 (2013/march) pump failed: 28k cold-start reflashed: no |
Year: 2008<br />
First sold: ?<br /> Pump started to fail: 86600 miles message popped up with it being extremely hot out. Not sure if that means the pump is actually failing or if it just needs service in general.<br /> Pump failed: hasn't failed yet and the system works fine when the temperature is below 90 degrees or so.<br /> Cold-start reflashed: Never |
on pump #2
I am in Ontario Canada, bought my car new in Nov 2010.
year: 2010 pump started to fail: 41000 KMs pump failed: 41500 KMs cold-start re-flashed: ? Pump and AWD ECU replaced under warranty.... Thank heavens!!! |
year: 2009 Ralliart
first sold: 5/09 pump started to fail: 40k Miles 6/13 pump failed: 40K miles 6/13 cold-start reflashed: 6/13 |
Year: 2014 MR
First Sold: 22 JULY 2013 Pump Failed: 200 Miles Cold Start Reflash:No Pump is being replaced |
