-   Evo X Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain-258/)
-   -   Tranny drain plug won't tighten, advice? (https://www.evolutionm.net/forums/evo-x-engine-turbo-drivetrain/711717-tranny-drain-plug-wont-tighten-advice.html)
evoul18 Apr 19, 2015 09:36 PM
Changed the transmission fluid, and the fill plug wont tighten all the way when using a torque wrench or ratchet. Seems to get to a "point" then get looser...it still can be removed, but I am not happy with it being how it is. It won't move when I try and tighten by hand, just never seems to get tight. Can't find any leaks tho, any advice? Thank you.
hoobastnk90 Apr 20, 2015 06:45 AM
O man that is no bueno. You can try to re-tap the hole.
zebra4 Apr 20, 2015 02:24 PM
Stripped the hole buddy. Re-tap.
evoul18 Apr 21, 2015 04:06 PM
Okay, thanks. Ordered a new drain plug...fingers crossed its the plug, if not then retap it is.
meckert Apr 21, 2015 05:49 PM
Look at your old plug threads, are they screwed up or filled with aluminum? The trans case is aluminum, the plug is steel--whats going to strip? The aluminum. Either find a larger plug and tap or helicoil the old hole to the stock size--no alternatives. If you used a torque wrench--was the measure foot ibs or inch lbs--they are not he same. Good luck.
evoul18 Apr 24, 2015 08:53 PM
The bolt thread was filled with aluminum. I definitely f**ked up the fill hole plug. So I am going to never touch it again and inquire at the dealership here or try my luck with a transmission shop to fix it. I appreciate the help. I probably over torqued it. So mad because it is easy enough to do, and a good way to save money, but now I just cost myseld 3x as much to get it fixed....live and you learn. Thanks guys for the feedback though.
hoobastnk90 Apr 25, 2015 09:11 AM
don't be to hard on yourself accidents happen. Like the other guy said just get a helicoil repair kit like this one. Not this size..but you get the idea http://www.sears.com/helicoil-thread...&mktRedirect=y
You just have to figure out what size you would need for the fill plug. And look at it this way at least it wasn't the giant drain plug and just the fill one lol.
Bob-o Apr 26, 2015 09:57 AM
Make sure you do another flush of the tranny before you put everything back together. Wouldn't want bits of aluminum floating around in there
