Tomioka 5.00 Final Drive gears
This is what they are stating on their;
"TR Final Drive Gear Set raises the overall gearing of EVO. It enables the modification of the final gear ratio, adjusting the power band and gear ratios to tune better performance car. Kit includes center ring gear and output shaft." if it is still unclear, then I suggest you read up on how gear mechanism and ratios work. |
Originally Posted by detroit pistins
(Post 11658066)
"TR Final Drive Gear Set raises the overall gearing of EVO. It enables the modification of the final gear ratio, adjusting the power band and gear ratios to tune better performance car. Kit includes center ring gear and output shaft." if it is still unclear, then I suggest you read up on how gear mechanism and ratios work. What are these used for? I think when the ratio goes in this direction the largest YAW effect from AYC is increased. |
These will further shorten the gear ratios of the X. You'll have higher rpm on the freeway, the car will feel snappier when accelerating, and you'll stay in each gear for less time due to the final drive ratio being shorter.
Why you would want to go even shorter I have no idea...
yea with a top speed of 100mph
Originally Posted by razorlab
(Post 11659748)
They got made so somebody thinks there's a good reason for them. |
