Warning Light (Exclamation Sign)
Hey guys, I have a evo x and for some reason i am getting this exclamation check sign with triangle.
I have also recently changed my timing chain. Is there any other reason this would appear? |
There's several reasons for it to appear. You need to check for codes.
the Triangle will appear if your maintenance timer runs out, if you're low on fuel, have someone unbuckled, have ASC/AYC issues, or any other kind of reason where the car thinks something is out of line.
Cycle through the menus on the dash and make sure nothing is "zero'd" out before you worry. -asher |
