sst clunk when turning ignition off
2008 X MR, mods to 300kw. high mileage (nearly 300,000 km, almost certainly the highest mileage MR in the world from my forum exp). Several months ago I hit a dead kangaroo which smashed the undertray and ever since (may or may not be related) my trans has gone "k'chunk" and jerked forwards on switching off. This happens regardless of whether the car is in park or neutral but seems to be much worse when it's hot. Any ideas? Thanks!
I should add that the car is obsessively looked after, serviced every 10,000K (approx 6200 miles) and never tracked, although the mileage is very high it's 90% highway cruising around 110 kmh (72-ish mph), and the power has been wound back from a high of 404KW ATW to 300KW at the crank. The clutches are original (!!) and the SST transmission fluid, whilst non-stock, was put in by TMR Australia who know what they're doing, less than 100,000k ago. (bout 70,000 from memory. Mitsu recommends every 100K)
Originally Posted by felixmjones
(Post 11785455)
(Post 11785479)
found your problem...
Hey I get it, not what you wanted to hear. I have never heard of TMR but I can tell you that every reputable shop in the U.S. advocates nothing but OEM Diaqueen MR-SST fluid. You can find countless threads about this if you do some searching.
(Post 11785485)
(Post 11785487)
TMR are Team Mitsubishi Ralliart Australia, and whilst i'm not here to sing their praises (mainly because they're only really interested if you have unlimited funds for them to prep your Targa racecar), they almost exclusively deal with Mitsus and mostly Evos at that, so (maybe naiively) I assume they know what they're doing, and if they use cheaper fluid I'd hope they've done the appropriate R&D. I'm going to replace the stuff they used with Diaqueen (at five times the price) and we'll see if it helps. In the meantime, if it's the fluid, any idea what exactly is happening?
Did changing the sst fluid work? I have the same issue.
