Some specific questions
I just got my Evo last week and it's so different from my previous cars (low power Toyota's) I looked around the forum (especially for the second question) and I couldn't find quite the answer I was looking for so I'm just going to ask here.
1. Is an Evo X's flywheel considered light? Or is it heavy? I noticed that the revs drop slower when compared to an FR-S or AE86, is this why? (Driving at normal speeds). This one is just a curiosity as it helps me a lot with shifting up. 2. The only 2 mods I'm planning on the near future is a BoV and a HKS Hi-Power Exhaust. Now I read from here that changing the exhaust shouldn't require a tune, but what about a BoV? Also, when I let my foot off the gas, I notice the car shutters a bit, is that due to the built up pressure? Would a BoV help this? (Even if not, I still want one. Need that PSSSSH in my life.) Thank you, I'm obviously new to this so any help is greatly appreciated! |
1. The stock flywheel is like 13lbs. I feel like you need the RPMS when shifting gears if your WOT to stay in boost.
2. Stock BOV is fine. IMO you would be wasting money. I would just rather get a Intake if you want to hear the 'Flutter'. Technically when your changing parts, you should tune. Maybe start with a Cobb tuner if your not comfortable tuning your self or take it some where to tune you. |
If you're not running an aftermarket BOV in recirc mode then you need a tune.
Originally Posted by laxhero2
(Post 11810149)
2. Stock BOV is fine. IMO you would be wasting money. I would just rather get a Intake if you want to hear the 'Flutter'. Technically when your changing parts, you should tune. Maybe start with a Cobb tuner if your not comfortable tuning your self or take it some where to tune you. Changing the intake would allow me to hear the blow-off flutter? I was looking into a Injen or AEM later on, but I know that requires tuning afterwards so I might as well do both at the same time. Thank you for the advice |
Heavier flywheels help street driven car with shifting. Helps the synchros and prevents “blocking you out of a gear” lighter flywheels are used in drag or racing applications because they are easier to rev for 1 and 2 they are shifting in high rpm all the time and don’t need the weight down low. To answer your BOV question if you get a BOV that is still 100% recirculating you will be fine with no tune but to get your loud “pshhh” sound you need something that vents at least 50%... i would do a intake, boost controller, and bov when your ready for a tune... |
Originally Posted by Rohtech
(Post 11810444)
Originally Posted by konosp
(Post 11810819)
thank you, sounds like a plan to me. I knew i was getting a vta from the get go, so your answer is exactly what i needed to know.
The loudest intake to hear the PSSSHH would be the Apexi one for the Evo X. It has a long aluminum MAF section that tends to echo out the PSSHH sound. Your car shouldn't be studdering or bucking. If you have issues, solve that first before you go changing & upgrading stuff.
Originally Posted by Jaraxle
(Post 11811517)
Now I just have to find someone to tune it after installing it, but if it really is that loud, I don't have to worry about getting in trouble for having a VTA haha |
