What clutch should I go with?
Trying to figure out what clutch I should go with. Debating between a twin or a triple and want to see what people with similar setups might be running.
It is a cosworth 2.2 with an hta3582r and shep trans, ID2000/twin pumps running on e85. Old clutch is slipping at around 22psi and she is making around 550 on a mustang dyno and that is as far as we can go with the clutch. Not sure if I can get away with a twin or I should just be safe and go with a triple. Aiming for 35-38psi hopefully. Just looking for recommendations, I don't care much for driveability as its not my daily driver. Car will see some track time. |
How many ftlbs? What kind of track?
Originally Posted by kaj
(Post 11838211)
Hoping to hit Sonoma and Thill. Possibly some 1/4 mile runs but I don't plan on that as of now. |
And a triple isn't holding it? Hmm..
Road racing with 600+. You gotta get video of that. |
That triple is probably just worn out and needs a rebuild. Or you have an SD cover on the triple and you need to switch to an HD. I have a triple in a car here; Evo8, 2.4LRwith a 6466 strapped to it making 830whp and 670wtq. Holds it just fine.
Either way, an HD exedy triple is more than enough for your needs. |
