[FIXED] EVO X smells like Gas from engine bay, the Heater/AC vents
My 2010 Lancer Evolution GSR has a strong gas smell when I park. It also smells a lot when my heater or AC is on. The car has 78k miles. |
Hey hello & welcome
Likely suspect would be the injector seals. Can be verified by a boost leak test. There are other ways, as well, like using a spray around the seals while the engine is running |
Check for a crack in the manifold and check for loose bolts/nuts along the exhaust, starting from the exhaust side of the engine.
Originally Posted by shanka
(Post 11868572)
Originally Posted by winterevox
(Post 11868710)
Sorry I forgot to update but the issue is fixed. There was a hold in the fuel return line from the intercooler piping. Made adjustments and replaced the part.
