SST vacuum hose/breather line at shift linkage
https://cimg3.ibsrv.net/gimg/www.evo...1d9d016ac.jpeg
https://cimg9.ibsrv.net/gimg/www.evo...580c6bbcf.jpeg Hello, Changing my SST fluid today and found a broken plastic fitting connected to a rubber hose at the shift linkage assembly on the top of the SST. Anyone know what this is? Or where I can locate a replacement? Thanks. |
This ventilation does not play an important role in the work of sst. just paste it and that's it.
same thing happened to me. Very carefully remove the broken plastic parts from the trans. You don't want them dropping in. Kozmic Motorsports sells a replacement.
https://www.kozmicmotorsports.com/mi...nsmission.html |
Hi guys, how did you fix that issue. Thanks
Originally Posted by Qian
(Post 11969756)
Jack's is where I got mine as well. Sticky grease on a pick will assist with those broken bits inside the link from falling into the trans.
