Sponsored by:
Sponsored by: CARiD
Understanding ASC: What it does and reported problems & codes (thread merge)
Old Nov 12, 2008 | 03:45 AM
  #121
SiC's Avatar
SiC
My car has gotten around 20 ECUTek flashes for tailored tuning and I have been playing around with ECUFlash and have not yet seen the ASC light turn on my car or any other cars that I have flashed.
Old Nov 12, 2008 | 04:26 AM
  #122
gunzo's Avatar
Originally Posted by lallen3
I have no idea what your point was...
Simple .. ECU signal mismatch ..
Whatever you hook up to the car that is not from the factory.. you're going to throw CEL .. if not now .. later .. at one point in time ..
piggyback modify the signals .. these signals cause mismatch with the wheelspeed sensors and the airflow sensors ..
Boost controller modify the engine load .. now your TPS and your engine load mismatch ..
MBC .. same as EBC .. especially at part throttle .. some people say the ""NEVER" get it .. thats because they "NEVER" gone into that region yet .. the weather is turning cold.. you'll see more of the MBC issues real soon ..
Old Nov 12, 2008 | 07:15 AM
  #123
TTP Engineering's Avatar
There are ZChip has users that have never had the ASC light come on, even with a bit more aggressive tune than the basemaps.
Old Nov 12, 2008 | 07:30 AM
  #124
Chris@AMS's Avatar
None of my customers have had any ASC light issues, from any part of the world. The JDM ECU's are all good too. I have flashed some cars over 50 times (due to changing modifications and testing) and have yet to have a problem when using ECUTeK.
Old Nov 12, 2008 | 08:28 AM
  #125
lallen3's Avatar
The main thing that we all don't understand yet, is that the ASC/ABS module is seeing something is outta whack with the engine, but the engine controller isn't detecting an issue. It occurs to me that if the engine detected a fault, it would set a code, then subsequently the ABS/ASC would be disabled. BUT, that isn't happening so it makes me wonder exactly what the ASC is really looking at in order to believe there is a fault. Until we know precisely which parameters the ASC is monitoring (for the specific DTC it sets), then it's all speculation. I cannot stress how much I'd LOVE to see someone pull a code at this point!!
Old Nov 12, 2008 | 09:48 AM
  #126
Spoolin11's Avatar
I have the WORKS P2 flash and have not had a single ASC light issue.
~Ryan
Old Nov 12, 2008 | 01:46 PM
  #127
DynoFlash's Avatar
Just to add that I have tuned just under 100 Evo X to date - both standard and SSR version - not one with any cel issue yet - I am using ecutek
Old Nov 12, 2008 | 01:48 PM
  #128
Magnumpsi's Avatar
I have done a lot of X's and I have not had this issue either.
EDIT--Using Ecutek BTW
Mitch M
Old Nov 12, 2008 | 06:42 PM
  #129
NateDaJew's Avatar
Why do you think some people get the light and others do not?
Old Nov 12, 2008 | 07:46 PM
  #130
JWA's Avatar
JWA
As a prospective customer, I'd like to ask: does TTP/Zeitronics see this as an issue that must be resolved? Your responses appear to be of someone who has pushed long and hard to get this ready and now when an unexpected problem appears you wish it would just go away. So, do you have a plan to resolve this issue?
Old Nov 13, 2008 | 04:02 AM
  #131
goforwand's Avatar
I'm sure they are working to resolve this issue, despite what might appear to be a defensive stance.
One has to be realistic in the sense that no vendor would continue to sell a product that could be percieved as flawed when there are other alternatives out there that are not causing the same issue.
I hope they get it rectified, as I think the z-chip has great potential.
Old Nov 13, 2008 | 07:40 AM
  #132
ToddMcF2002's Avatar
I bet they are running in "Snow" mode which practically disables traction control.
Old Nov 13, 2008 | 07:42 AM
  #133
We are reviewing as much data as possible comparing those who do not get it to those that do to try and learn as much as possible about it. It very well may turn out that those with the dealer update flash do not get it.
Time will tell.
In the meantime, the ZChip has been busy winning 2 SEMA Global Awards. From what I understand only 10 of these awards were given out at SEMA 2008 in Las Vegas last week out of 2000 products showcased and the ZChip took home two of them.
Old Nov 13, 2008 | 07:43 AM
  #134
If you were a betting man, you would have lost because the ones not receiving the light only use TARMAC mode.
Old Nov 13, 2008 | 08:29 AM
  #135
lallen3's Avatar
I have the Dealer reflash for misfire above 5KRPM, got it done about 3 weeks back, and I do get the Service ASC warning.
In Tarmac mode, I get the warning all the time, even normal driving.
In Snow mode, the warning is less frequent, only occuring near redline shifting, especially from 1st to 2nd gear.
