Sponsored by:
Sponsored by: CARiD
PITA screw clips
Old Feb 25, 2009 | 04:24 PM
R0ME0's Avatar
PITA screw clips
Is it just me or are those screw/clips a PITA on the X? I'm talking about the screw slips that hold down the OEM snorkel and the wheel well lining. Its like if i use a screw driverand unscrew it they don't unscrew and after a few attemps the phillips pattern is all messed up because the plastic is super soft. Anyone have a good way of taking them off? I was thinking of replacing them with the clips that are used to hold in the under tray. Share your thoughts!
Old Feb 25, 2009 | 04:25 PM
sl0ev0's Avatar
all clips like that are a PITA
Old Feb 25, 2009 | 04:29 PM
casper980's Avatar
Try not to press in as you turn, yea they suck
Old Feb 25, 2009 | 04:45 PM
JoeyM3's Avatar
the clips on the x are 10000000x better than the one's on the 9. but do what casper said, dont put pessure on the screw head when unscrewing so it backs out by itself.
Old Feb 25, 2009 | 04:52 PM
Evolution7GSR's Avatar
then when you get them all out go to autozone and get the ones that relaese when you push on the middle.. so hot.
Old Feb 25, 2009 | 05:14 PM
EndlessRed's Avatar
you can replace all of those plastic screw clips with the flat clips you can easily pop out with a flat head. it'll save you so much time and frustration.
Old Feb 25, 2009 | 05:15 PM
R0ME0's Avatar
agreed I think i'm gonna do that!
Old Feb 25, 2009 | 05:17 PM
jls0711's Avatar
Old Feb 25, 2009 | 05:19 PM
Grendelrt's Avatar
The key is to not put any pressure on them and not to use anything powered.
Old Feb 25, 2009 | 05:29 PM
Curt@MrLed's Avatar
Former Vendor
You can also squeeze the back of the clip while turning it out.
Old Feb 25, 2009 | 06:06 PM
Clipse3GT's Avatar
If accessible use needle nose pliers and then use a screw driver. works like a charm.
Old Feb 26, 2009 | 06:15 AM
stokEd's Avatar
I reach underneath the crossmember and push UP on the screw as I'm unscrewing it and it works like a charm. It is somewhat of reach, but I have relatively big hands and it's no problem. And I recently replaced the stock screw clips with ones I found at Lowes as well.
Old Feb 26, 2009 | 03:03 PM
Jblade's Avatar
tell me more Is there a specific brand or packaging I should look for?
Old Feb 26, 2009 | 03:13 PM
LVSBB6's Avatar
PITA indeed.
Old Feb 26, 2009 | 04:45 PM
MrBonus's Avatar
I use a knife and slide it up underneath the cap of them if they're particularly tough.
