Sponsored by:
Sponsored by: CARiD
Gauge pod options
Old Jul 14, 2010 | 06:05 PM
  #136
ToddMcF2002's Avatar
Those triple dash guages look great there, like the ATi setup for the GD STi. Why can't anyone make a nice flush fitting triple pod to shroud 3 guages? Really how hard is it? Everything I've seen doesn't sit right on the dash and leaves goofy looking gaps. Less carbon fibre, more fit and finish!
Old Jul 15, 2010 | 09:29 AM
  #137
go_dlee's Avatar
Originally Posted by pstl_pete
Ill see if I can post up a PDF of the story. Im traveling right now so I wont get to it until next week.
Everything that you see in the photos is all from DEFI, mounts, gauges,etc. TEIN USA is their official distributor so you can get all the parts from them.
for the PDF!
Old Jul 21, 2010 | 06:55 PM
  #138
pstl_pete's Avatar
Alright here's the story. Let me know if you guys have any other questions.
Old Jul 21, 2010 | 07:00 PM
  #139
samul said's Avatar
diggin the summit part.
Old Jul 22, 2010 | 09:11 AM
  #140
stealthMR's Avatar
For those who like the summit pod, but hate the faux carbon fiber look.
Glowshift has the exact same pod and it's in black and cheaper.
http://www.glowshiftdirect.com/Unive...-Dash-Pod.aspx
Old Jul 22, 2010 | 09:41 AM
  #141
fknchristoph's Avatar
My set up. bought it used, repainted it. Dont know who made it.
Old Jul 22, 2010 | 07:50 PM
  #142
utggevox's Avatar
So what do you gentleman think the best A pillar 3 pod is?
Old Jul 22, 2010 | 07:57 PM
  #143
Parikh1234's Avatar
Originally Posted by gizmotoy
I was thinking the same. The plastic appears to match OK, but it still looks like you bolted it on the dash, and the passenger can even see some kind of hole or something from the looks of it.
I still think this is the better solution, which replaces a dash piece with a matching one, so it doesn't look tacked-on. Of course, only the molds are done so these are just prototypes:
I just installed the CPE one above the OEM gauges and drove to las vegas with them. No issues seeing over the hood (im 5'11"). It was the best option and they integrate perfectly. I should be getting my car back tomorrow. Ill post picks.
Also, i heard its bad to put gauges into the A pillar because it houses an airbag. Last thing I want is gauges flying into my face during an impact.
Old Jul 25, 2010 | 08:48 PM
  #144
LRA_Joe's Avatar
Paint the pod first with plastic adhesion promoter then with a "terracotta finish" from the craft store. It gives a very uniform slightly textured finish. Then flat, Satin Black, or Semi flat Black. Sure its not actually factory texture but it looks very good.
Old Jul 27, 2010 | 06:13 PM
  #145
f1r3w0rk's Avatar
Thanks for the article sir!
Old Jul 27, 2010 | 06:16 PM
  #146
Bob Evolved's Avatar
mines
Old Jul 27, 2010 | 06:19 PM
  #147
evonewb29's Avatar
are there any 3-guage A-pillar pods that will still allow you to use youre sun visor? I bought my car with the guages already installed and HATE how i cant use the sun visor when need
Old Jul 27, 2010 | 06:39 PM
  #148
Ron burgandy's Avatar
Agency power triple gauge pod looks nice.
Old Aug 14, 2010 | 10:35 PM
  #149
Bluewind's Avatar
Originally Posted by EvoLou
Just so every one knows.. You CANNOT do this install unless you have the NAV system.... The base stereo has a 2 inch wire that plugs into the power switch which turns the radio on.. The power is coming from the passenger airbag/seatbelt light/hazard light switch.. FYI...
They retain their passenger airbag/seatbelt lights. They relocated it down under the A/C controls.
Old May 16, 2011 | 09:58 PM
  #150
blonde's Avatar
finished my custom gauge pod (took the idea from Joe in this thread). i decided to do some more cutting to move the gauges as far to the right as possible and i also spaced them out a bit more. i am currently working on another version that will be a bit different so this one will be sold. it is not perfect since you can see that the top left corner of the double din opening is not straight but other than that, i think it came out pretty good
