Sponsored by:
Sponsored by: CARiD
HELP: Some rattling noise
Old Jul 24, 2012 | 09:47 PM
RoMeIX's Avatar
I would advise you to start listening to the stereo louder or learn to ignore rattles, it just gets worse lol
Old Jul 25, 2012 | 10:56 AM
tori240's Avatar
I've found this to be a good method of dealing with rattles. Haha
I did have a strange rattling/clanking noise I could hear from the drivers side rear of the car, and had given up on finding it. Come to find out it was my windshield fluid reservoir. It was unbolted and making what sounded like metal on metal banging around. May not be your issue, but worth checking since it's a very simple fix.
Old Jul 25, 2012 | 11:12 AM
black95tt's Avatar
I remember reading a thread about the cross brace behind the rear seat being loose on several cars causing a difficult to trace but annoying rattle. Worth a shot at the very least.
Old Jul 25, 2012 | 05:49 PM
2x4's Avatar
2x4
Thanks for the ideas! I'll check Both of these out. If all else fails I'll give the music a try.....
\m/(-.-)\m/
Old Aug 1, 2012 | 07:55 PM
2x4's Avatar
2x4
I narrowed down the source of my rattle coming from the rear of the car. The rattling stops when I apply the brakes. Spring loaded pad clips??? Anyway, off to the dealership soon.
Old Sep 23, 2012 | 03:51 AM
whitenight's Avatar
any luck finding this rattle i have the same problem its coming from the left rear sounds like a loose bolt washer, happens when i go over excesive bumpy roads but goes away when i apply the brakes , have checked every thing brake caliper , shocks , bearing hub , checked diff hanger , and also drive shaft nut , everything is tight , im all out of ideas. ready to take the rear bumper off to see if anything is loose behind the plastic bumper.
Old Sep 23, 2012 | 08:57 PM
2x4's Avatar
2x4
I haven't had any luck. My next step will be to make sure the calipers are torqued properly. Past that I think I'll pull the brake pads out reinstall and make sure the anti rattle clips are tight.
Old Sep 24, 2012 | 12:53 AM
Panda_stunter's Avatar
u said ur suspension was changed? it could easily be a nut thats not tightened or became loose. i know this coz when i helped my friend to installed his springs, his came loose and started rattling. when we tightened it up, it went away.
Old Sep 25, 2012 | 11:38 PM
whitenight's Avatar
i have come to conclusion that it is the rear cv joint closest to the diff on the left side it has excesive play in it so when i apply the brakes it actually loads the cv which intern stop the rattle i have a few friends look at this problem with me and they agree on it . i have never heard of cv rattling before .now i just have to take it in to the dealership to see if they agree with me.
Old Sep 25, 2012 | 11:46 PM
mp72's Avatar
I had a rattle in the back of my car. It turned out to be the bolt that holds the spare tire in place. All I had to do was tighten it and the rattle was gone.
The standard Evo X interior rattles don't bother me because my exhaust and stereo cover it up.
Edit to say: Why did someone bump a 2009 thread about rattles in an Evo? lol
Old Sep 26, 2012 | 04:56 AM
2x4's Avatar
2x4
Whitenight: Good luck. Let me know how it goes. My dealership thinks the noise is “normal”.
Mp72: Standard rattles don’t bother me either, this one is different. I resurrected the thread since simonlam168 seemed to be having the same problem and I had hoped he had figured it out since he seemed to be throwing a lot of time and resources at it.
Robert
Old Sep 26, 2012 | 05:39 AM
Johnr352's Avatar
Be careful. The caliper bolts are steel, the calipers are aluminum and those threads can be ruined by over tightening. Strip it and you have to replace the caliper or helicoil the hole. I suggest you spray it with wd40 or PB blaster, loosen the bolt, clean it off and then reinstall it using a torque wrench to spec.
I'd be surprised if the bolt is the source of your rattle.
Old Sep 26, 2012 | 05:45 AM
2x4's Avatar
2x4
Johnr352: Thanks for the heads up. I am the type to "over do" things.
Old Sep 26, 2012 | 05:58 AM
xTiCkxMYxLaInTx's Avatar
There are a few spots that rattle in mine. They don't really bother me but here is what rattles a little bit:
-Driver Side where the seatbelt comes out of the pillar
-My Double Din with my Kenwood DD419
-Radar Detector
I'm going to try and use some sound proofing to help it out.
Old Sep 27, 2012 | 03:30 AM
whitenight's Avatar
Robert
i really dont think the rattle is normal
as for the spare tyre bolt we dont get a spare rim in the boot/trunk of our evo's in australia we get a 12v trye pump and some goo.
SFL Autosports
98
Apr 9, 2018 09:02 AM
jnathan68
Jan 20, 2015 06:14 PM
ConceptVBS
21
Feb 23, 2011 07:57 PM
meat_EVO
Sep 30, 2010 08:52 AM
lethalvenom
19
Jun 2, 2009 07:07 PM
