uh oh... (idle issues and power loss)
So you went from a good base...to a..good base? wtf FML. I only had 3 Air Force bases in America I could go to with my AFSE cause I mainly get stationed at Army Bases. I got lucky McGuire AFB, NJ!!!! WOOO HOOO
if you want to consider lakenheath a good base when i worked 12 hours a day 6 days a week for 2 years, then i guess its good lol
Location Wise its good... Dude I dont have shifts, i work sometimes an hour a day, sometimes all day and night..lol I deploy on a few days notice, given, they are only 2-6 weeks deployments...
but trust me, it could be worse. lol
well finally figured it out. the MAF housing was cracked and yea doesnt look good. so i had it towed into the dealer thinking it would be warranty, i was wrong. since the housing is cracked and not an "internal problem" they are not covering it under warranty. i love it lol. i called in and made a case to see if they will cover it. ill get a call tomorrow from the case worker to see if they will cover it or not. im not gettin my hopes up.
Why the eff wouldn't mitsu cover it, are you out of your drivetrain warranty? I would tell them to fix it, its a stupid problem and the maf housing is prolly a $5 part.
I also had starting problems and idle issues but it was related to a Custom Tune ( a simple issue they forgot to get rid of the LIMP safety mode)
Also my battery was weak so it was replaced under warranty.
Idle issues usually resort to MAF issues.
The car not starting can be many problems from the ECU (communication- it can be wires and etc), battery, and sometimes the Fast Key (Key is not properly programmed, fast key disruption from key in the pocket with cellphone and metallic objects, and etc)
