Sponsored by:
Sponsored by: CARiD
Stumbling Idle starting Again!
Old Jan 10, 2010 | 02:33 PM
wicked white14's Avatar
OK, so it is starting to happen again. Car is bone stock and had factory re-flash done about 4 months ago. After the car has been driving, if it is turned off then re-started 10 minutes later the idle will stumble back and forth between 100-1,000 RPM's before it smooths out to idle at 750 RPM. Car has done this twice in the last week, after it idles for a minute like this it smooth out without dying or re-start. Anyone have an ideas???
AA
Old Jan 10, 2010 | 02:45 PM
Bladed's Avatar
my 08 lancer GTS does the same thing, I thought i might have a crack in my head gasket or something because my coolant is always low. I turn it on and it works fine but if i turn it off and turn it back on it shakes and idles very rough and sometimes the engine cuts off and i have to keep restarting it.
Old Jan 11, 2010 | 10:23 AM
Evostare's Avatar
Why don't you try disconnecting the battery for 25 minutes and then connecting it back in?
That will reset the ECU and probably fix the idle issues.
Raceghost
25
Jan 27, 2017 03:20 PM
xXANCHORMONXx
Jan 4, 2013 04:13 PM
yenny
AEM EMS
Oct 7, 2012 02:24 PM
C130flyer
Jul 19, 2012 08:13 AM
Sschmuve1
Aug 24, 2009 10:40 AM
