Sponsored by:
Sponsored by: CARiD
Jack Points
Old Apr 9, 2010 | 12:35 PM
westmc's Avatar
Jack Points
I looked under the car to try and find the marked points along the rail that runs next to the rocker panels and I found 4 distinct areas. The owner's manual seems to point to the outer most ones but they don't mention the inner ones at all. Are they meant for jack stands? I tried searching on here but only the outer ones seem to be mentioned (along with the central front and back ones).
Every car I've owned, I've used the inner frame rails (the ones that are about 3" wide and about 1' in from the car. Normally, I would have used them without 2nd thought but the fact that nobody else here seems to has me concerned. Why doesn't anybody use them?
Old Apr 9, 2010 | 01:17 PM
stokEd's Avatar
I've used the middle lifting points before when I needed to support the front of the car on jack stands. You can use them for lifting, but don't use them for jack stands as the car can teeter.
If you're lifting the front, the manual says to use the lifting point on the front support member which is shrouded by the plastic cover underneath the car (wtf.) I cut a hole in mine to have access to it, otherwise you have to squeeze underneath there and un-bolt/pull a dozen fasteners to get it off. For those lowered more than 1" in the front this won't be an option without having the car on ramps or 2x4s.
Old Apr 10, 2010 | 06:45 PM
EEVOH's Avatar
I just did that last weekend when jacking up my car to change the oil in my car. What a PITA it was to pull that cover off... I may cut a hole in mine next time.
Old Apr 10, 2010 | 07:05 PM
dek0026's Avatar
^dude just jack it up on the passenger side enough to get under it and upscrew the access panel to the drain plug and filter.
Old Apr 11, 2010 | 08:48 AM
EEVOH's Avatar
My jack barely fit under the side skirts. I always use jack stands too. The only jack point I found was in the way of the jack stand location.
Old Apr 11, 2010 | 09:02 AM
Fidget253's Avatar
on all my cars i have always just used the rail that runs across the whole car, im not sure how to better explain this, but honestly as long as when you are jacking the car up, if you make sure its not bending anything then you should be fine
Old Apr 11, 2010 | 11:05 AM
EEVOH's Avatar
My little 3 ton floor jack couldn't make it to the rail on either side of the car due to the side skirts. My only choice was to jack up from the front. My car is currently at stock height, so when I do the suspension it will be even worse
Old Apr 11, 2010 | 11:12 AM
wiretap's Avatar
If your car is lowered, drive up on some boards first, then you can fit the jack under/behind the side skirt where the factory recommended jack location is located.
Old Apr 11, 2010 | 11:14 AM
Fidget253's Avatar
you can get a low profile jack for around 100 bucks. they easily fit under the car, im lowered 1 inch and my floor jack still fits
Old Apr 11, 2010 | 11:16 AM
Fidget253's Avatar
BTW this is the jack i have http://www.harborfreight.com/cpi/cta...112&zmap=67045 but there is a craftman for 59.99 that should work also :-) check it out at sears.com
jmrussell89
Nov 6, 2024 06:01 PM
turbotaloon95
Sep 14, 2016 11:52 AM
Jedi_Gill
10
Apr 24, 2014 09:54 AM
Rob_GPT
Mar 30, 2011 10:59 AM
Andrew LB
Apr 17, 2006 06:07 PM
