Sponsored by:
Sponsored by: CARiD
Failed Emissions...what to do?
Old Jan 22, 2011 | 09:10 AM
BAMFevo's Avatar
Failed my emissions test today due to the fact that my check-engine light was on due to overboosting. They told me I need it cleared before I can pass my test. My question is can I just take this to my mechanic to fix this or do I need to take her in to a Mitsu dealership? Thanks in advance.
Old Jan 22, 2011 | 09:18 AM
migs647's Avatar
The bigger question is, why were you overboosting? Did you get a tune and someone forgot to disable the error code?
Old Jan 22, 2011 | 09:27 AM
milford's Avatar
Go to autozone or like store and have them clear it..its free. Then go back and re take your sat's or emissions w.e. it is.
Old Jan 22, 2011 | 10:23 AM
Hoooshlava's Avatar
make sure you drive it around enough to put the ecu in the "ready state" once you do this.
Old Jan 22, 2011 | 10:49 AM
dboz's Avatar
Unless you are friendly with your AUTOZONE store, they are no longer supposed to clear codes. They would do the scan, but will not clear it for you.
You can get a cheap OBDII reader/clearer at Harbor Freight. Worth the money, since with these cars, I seem to need it regularly.
Old Jan 22, 2011 | 11:24 AM
migs647's Avatar
You can also buy a tactrix cable and clear them that way. That way, you aren't wasting money and can tune or monitor your car.
Old Jan 22, 2011 | 11:44 AM
linjy2's Avatar
or pm a nice evo member in your area to maybe help to read and clear your code.
Old Jan 22, 2011 | 12:18 PM
beetle_orange's Avatar
i guess my question is why waste time in going if you saw your CEL on?
Old Jan 22, 2011 | 12:22 PM
tripperfx3's Avatar
Werd!
And even after the code is cleared you need to drive it for a while like mentioned so the ECU can get back in the ready state.
Old Jan 22, 2011 | 01:24 PM
Robevo RS's Avatar
Old Jan 22, 2011 | 04:41 PM
Kracka's Avatar
How about just disconnecting the battery for a few minutes then driving it around a bit to get everything back to readiness state?
Old Jan 22, 2011 | 05:17 PM
Fittest's Avatar
OP said he has a mechanic so yes, go to your mechanic. Now next time you are going to get any car smogged, make sure it doesn't have a big yellow light that says "Check Engine".
If you go back to the same smog station, the rep will probably be on to you and check for more things than just the light. If your overboosting issue is affecting your emmissions negatively, he is for sure going to catch that way past a simple CEL.
Also, he is more likely to look for aftermarket parts to fail you on the visual inspection portion.
That is, of course, if he isn't a "cool person".
Old Jan 22, 2011 | 07:27 PM
migs647's Avatar
Originally Posted by Robevo RS
Thank you, was beginning to wonder if my post was invisible
Old Jan 22, 2011 | 09:13 PM
J5isalive2's Avatar
because most people dont understand all the checks the car does before it reverts back to a ready state.... there are many conditions that need to be passed such as cold starts, etc, etc. All the checks could be taken care of in 15 miles, or it could take 100.... its hit or miss really, unless ofcourse you know exactly the tests that need to pass to put it in readiness state
sdheath
Jul 30, 2012 05:21 AM
cajjj34
12
Mar 25, 2011 07:49 PM
hammerevo
May 30, 2008 11:51 PM
ruzs
Nov 14, 2007 04:18 PM
DaTenshi
Mar 31, 2007 07:49 PM
