AGP catch cans
AGP catch cans
Whats the difference between the AGP Oil Accumulator catch can and the AGP valve cover breather? Im going to need one that will take the valve cover side. The driver side. Are these two the same thing but one for the valve cover side and the other for the other side?Will the Oil Accumulator catch can be mounted so it can be on the valve cover side? Need an answer thanks guys.
Do you have some links that might help us look at pictures of the parts.
From what I can see the difference is the catch can recirculates the air while the breather vents the air, both intend to separate the oil from the PCV system.
We use Moroso's new Evo X air/oil separator, which I highly recommend. We use one, on the driver's side, you should see the quantity of oil and water this thing collects. It is mounted on the front of the motor with lines that run over to the driver's side.
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
