Sponsored by:
Sponsored by: CARiD
do-luck trunk vs Replicas....
Old May 25, 2012 | 08:45 AM
CmakEVOX's Avatar
How do you spot a replica/fake do luck trunk from the real one? I know there are some fitment or quality issues, but is there a badge or a seal that says Do-Luck underneath the trunk?
Old May 25, 2012 | 08:50 AM
manolo2011's Avatar
is the VIS Carbon one a REAL ONE? which one is the real one?
Old May 25, 2012 | 08:59 AM
CmakEVOX's Avatar
I consider Do-Luck as real/authentic since they came up with the design and then the rest "replicated" or "Copied" the design....?
Old May 25, 2012 | 09:17 AM
ugakirk's Avatar
+1 The authentic trunk was made/designed by Do-Luck. There are knock-offs such as Vis, Seibon, and others just like every other CF part out there.
I believe the Do-Luck trunk has a metal tag/badge inside the trunk their Emblem and a serial number for each trunk.
Old May 25, 2012 | 10:06 AM
manolo2011's Avatar
who sells the REAL DO-LUCK?
Old May 25, 2012 | 10:44 AM
CmakEVOX's Avatar
BPauto, they are a vendor here.
https://www.evolutionm.net/forums/ev...trunk-lid.html
Old May 25, 2012 | 10:46 AM
CmakEVOX's Avatar
Thanks. Im purchasing a used Do-Luck Trunk locally and want to make sure it is legit.
Old May 25, 2012 | 11:28 AM
Evod350z's Avatar
How much if you dont mind me asking?
Old May 25, 2012 | 03:24 PM
Trickraca's Avatar
Its actually a tag of sorts under the inside of the trunk. I bought supposedly the first evox do luck in the us. Although mine says evox do-luck-005
Old May 25, 2012 | 06:07 PM
CmakEVOX's Avatar
getting it bundled with other stuff. but used are still going for more than a brand new "Replica".
Old May 26, 2012 | 08:43 AM
jdmEviL8's Avatar
^ id rather get a used do-luck than a new replica as well
aren't the do-luck only 1x1 carbon weave? most if not all replicas are 2x2 weave
Old May 26, 2012 | 08:51 AM
Alpha X's Avatar
What's the difference between the 2?
Old May 27, 2012 | 09:23 AM
Trickraca's Avatar
Quality of the weave. If you look at them side by side you can tell the difference.
Old May 28, 2012 | 07:28 PM
Pargy's Avatar
You can have the SSS wing with the do-luck trunk, right?
I'm considering getting one but i like the wing.
Old May 28, 2012 | 08:30 PM
Alpha X's Avatar
Okay gotcha. I was just getting ready to purchase a do-luck trunk.... but decided to go with some new wheels, a vortex generator and a 1lb shift knob
