Sponsored by:
Sponsored by: CARiD
Ack! Evo X Won't start
Old Aug 22, 2012 | 06:46 AM
thrlskr's Avatar
Need help...gotta get to work.
2008 Evo X MR
Cranks just fine...battery fine...plenty of gas in tank...still won't start.
Fuel pump relay has been replaced and vacuum hose is zip-tied. No trouble codes, swapped MFI Relay for other relay, still a no go.
Ideas?
Old Aug 22, 2012 | 07:09 AM
vegittoss15's Avatar
2008 Evo X MR
Ideas?
What is it exactly doing? Could you get a video?
Old Aug 22, 2012 | 07:15 AM
thrlskr's Avatar
I just turns over like normal but won't start...doesn't really attempt to fire up.
Old Aug 22, 2012 | 07:27 AM
hawaiianstyle's Avatar
Starter broke? Or spark plugs? Coil packs?
Old Aug 22, 2012 | 07:57 AM
thrlskr's Avatar
How do I check the starter? (It is turning over after-all) How do I check coil packs?
Old Aug 22, 2012 | 08:11 AM
If it turns over then it's not the starter. Have you done any recent mods? Are you receiving any warning messages?
Coilpacks I'm assuming you'd have to take each one out and use voltage tester to see if they're working but it's prolly not that.....just throwing stuff out there for you.
Old Aug 22, 2012 | 12:04 PM
teameditevo08's Avatar
Check your grounds
Old Aug 22, 2012 | 09:22 PM
Johnr352's Avatar
Can't really check coil packs w a voltage tester. At least I don't know how.
Seems unlikely all the plugs would go bad at once. I'm thinking fuel. You need to get this car to a shop. The ony other thing i can imagine is a problem with the fast key. Any changes to your eys?
Old Aug 22, 2012 | 09:56 PM
quicksevo's Avatar
Check fuel pressure and also check ALL your fuses
Old Aug 22, 2012 | 11:29 PM
poof101's Avatar
When my X wouldn't start, it was my timing chain.........don't mean to scare you
Old Aug 23, 2012 | 07:11 AM
EvoForumUser12's Avatar
Disconnect the injectors. Crank the engine over a few times. Maybe clean the plugs. Reconnect injectors and see what happens.
Old Aug 23, 2012 | 08:38 AM
Dbzguy's Avatar
Were you parked on a grade with the front end elevated for an extended period of time?
Old Aug 23, 2012 | 04:04 PM
thrlskr's Avatar
Update: still need help. Parked in my level garage for 4 days.
1. Removed plugs. Turned engine over.
2. Disconnected Fuel injectors. Turned engine over.
3. Installed plugs and connected fuel injectors.
4. Tried to start car. No luck.
5. Used jumper cables from wife's suv (running) because battery was sounding mildly weaker.
6. Tried to start car again. No luck.
7. Inspected every fuse with engine symbol. Good to go.
Effin furious. No recent changes in anything, but no go.
Old Aug 23, 2012 | 06:32 PM
rkevo's Avatar
Did you check for spark?
Also, if you live in the midwest maybe you got some of the bad gas that came out of BP's Indiana refinery.
Old Aug 23, 2012 | 10:04 PM
quicksevo's Avatar
You should check every fuse not just the engine fuses..if you have a spark tester try it out, pull out the coil and put one end in the coil and the other on ground and see if there is spark you can get a cheap one at an auto parts store
