Sponsored by:
Sponsored by: CARiD
Ets intercooler tuning question.
Old Nov 17, 2012 | 07:08 AM
dldjros69's Avatar
Im going to be installing my 3in ets intercooler on Saturday 11/24. I still have to work Sunday. 3 mile drive each way, and then to the performance shop 15 miles away. If i stay out of boost and keep the rpms below 3000 will everything be ok?
Mods are in my sig. Cobbap - stage 2 93, sf, cbcs
Thank you.
Old Nov 17, 2012 | 08:24 AM
Evod350z's Avatar
Dude youll be fine man...
Old Nov 17, 2012 | 10:15 AM
TheBlade's Avatar
I installed my listed mods sans 3port and drove without my tune and had no problems.
FWIW, it was much easier to install the LICP by connecting to coupler nearest the intercooler first then to TB. Removing the bumper cover was easy too. Here's a pic I have of the day I did it:
Old Nov 17, 2012 | 11:23 AM
SD_Lurker's Avatar
You don't really even need to tune if just an intercooler.
Old Nov 17, 2012 | 11:28 AM
TheBlade's Avatar
He had other mods in his sig though. Tune is probably suggested since one was a test pipe and another I think is the Cobb 3port
Old Nov 17, 2012 | 03:06 PM
dldjros69's Avatar
Thanks for the heads up guys. Ill def baby it. Ill be logging the whole time, so if something goes down ill flat bed it.
Old Nov 17, 2012 | 09:46 PM
MisterHappy's Avatar
No tune required with a Intercooler. If you are running your other mods fine, you shouldn't have to worry with the addition of the intercooler.
Old Nov 19, 2012 | 06:45 AM
EAGLE 5's Avatar
If anything adding an intercooler makes your car more stable by lowering charge temps making it less likely for detonation to happen so you'll definitely be fine running that mod without additional tuning.
Old Nov 19, 2012 | 08:26 AM
ETS Michael's Avatar
You will be fine
Michael
Old Nov 20, 2012 | 07:05 AM
Get Rad's Avatar
All you are doing is increasing the surface area to allow for greater heat dissipation through the intercooler. So you are just adding cooler air. Think about it like this, would you tune your car every time the temperature dropped?
Old Nov 20, 2012 | 02:25 PM
TheBlade's Avatar
Maybe I'm a little crazy, but every winter and every summer my tuner has a dyno-day. I have him touch up the tune. If I ever get to the point of not mod'ing my X, I'll likely run a winter and summer map. But I'm a little OCD, and Phx summers get crazy hot.
Old Nov 20, 2012 | 04:45 PM
dldjros69's Avatar
I understand all that but i thought it increased the air flow a little. A little less resistance?
Old Nov 21, 2012 | 03:53 AM
nastorino's Avatar
Originally Posted by ETS Michael
You will be fine
Michael
I think this guy might know what he's talking about
The intercooler won't negatively affect the tune on the vehicle nor make it go lean.
Old Nov 22, 2012 | 03:48 AM
dldjros69's Avatar
^Haha yea im with you on that.
Old Nov 22, 2012 | 11:45 AM
Foolproof's Avatar
No need to worry or even get a tune unless you want to.
